Certified Porsche addict
The Glademister's Avatar
Caliper questions.
Taking a hard look at my rear calipers...
Is there a inexpensive way to bench test calipers?
If you apply pressure with brake fluid obviously the piston should extend but without applied pressure should it retract?
What areas should one lubricate after installing fresh pads? I noticed that the caliper doesn't "float" easily.
Thanks.
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 12-16-2009, 06:53 AM
Send a message via AIM to Icey1174
Take the caliper right off. You will see where it slides back and forth. You can grease the sliding area up. Don't use so much grease that it will end up on the rotors and pads.
They will extend under pressure but they don't really "retract" with no pressure. The lack of pressure and the movement of the caliper allow it to retract enough for the rotor to spin freely. If you have the tire off, the caliper on, you step on the brake pedal then release it, you will see that the pads are still reasonably tight on the rotor with no pressure on the brake system. You will be able to turn the wheel by hand and should become easier to turn the more you turn it as it is opening up the caliper.
After the calipers are on the car for a while they should still move, but they will not move quite as freely months (or years) later then when they are cleaned and freshly greased.
Do you suspect a problem with the rear calipers for some reason?
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 12-16-2009, 08:48 AM
Thanks for the reply Icey. The DS rear wheel was hanging up and getting really hot. I thought it was the parking brake but after recreating the condition, pulling the wheel off and inspecting - it's actually the caliper. The pads in that one are toast so tonight when I get parts I plan on...
Cleaning the both rear rotors really well (the calipers are off).
Installing the pads and lubricating the "float" areas and the retaining pins.
Install the calipers, seat the pads and test drive.
I studied up on disk brakes yesterday on Wikipedia. There was a really detailed and technical link that others here may be interested in...
StopTech : Balanced Brake Upgrades
According to the writer there are several reasons someone mistakenly would believe their cars rotors are warped. Unless plainly visible when rotating the hub - I think a using micrometer is the only way to be certain.
Old 12-16-2009, 09:08 AM
There is a good chance you may need a new caliper. I had a frozen caliper in my cargo van. I could not compress it with a c-clamp. My inside pad was worn right to the metal. New caliper, pads, and greased slide pins and all is well.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 12-16-2009, 09:21 AM
That caliper is probably o.k. I was able to push the piston in and remove the pads - no problem. I've actually got backup calipers in a slightly less desirable condition. I cleaned those up last night also. One has a frozen bleeder that can be extracted if needed.
Old 12-16-2009, 09:56 AM
Grease the slide section, clean them up good, put the new pads in and you should be good to go.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 12-16-2009, 10:25 AM
Proprietoristicly Refined
John_AZ's Avatar
Here is a picture that might help.
Use a wire brush to remove rust and oil/dirt buildup on all lube areas of the caliper prior to lube.
Old 12-16-2009, 10:55 AM
Yep, that did the trick! New pads, lube the rub points and thoroughly clean the rotors. That DS must have been binding because the caliper wasn't floating and deposits on the disk surface.
Old 12-17-2009, 07:06 AM
racer951y's Avatar
Send a message via AIM to racer951y
I know what parts store you shop at use to be a manager at one of those moved over to the competition about 6 months ago. Also I need to down load a photo off my phone but had a guy bring in a rotor that at first i thought was a funny looking drum till I saw the remains of the disc on the outside. his caliper froze on his work truck and he did not know till he was doing a brake job and found the caliper in pieces and no rotor left at all just the hub part
'82 928
'86 951(RIP)
'90 944 S2 Cab (RIP)
'92 911 C2
Old 12-17-2009, 11:02 PM
John_AZ's Avatar
I worked at Checker Auto in Tucson for a couple of years when I was in school (UA/Pima CC). Passed the polygraph every year! Now I shop AutoZone for fluids and Jeep parts even though Checker/OReilly is closer.
Old 12-18-2009, 04:24 AM
