DME and AFM update?/ Turbo Intake Manifold?
i was looking into upgrading the DME and AFM from an 86+ as i heard it was good for drivability. also when it comes to custom DME tuning, all the aftermarket chips are for.
my question is how does this upgrade work. since the later cars are 16valve doesnt the swap mess with the timing or anything?
ALSO:
will the turbo Intake Manifold fit onto the Early NA's? im NOT looking for performance gains from it! its just the principle!
1984 944 - black exterior, black/tan/brown interior (somehow it works....) 100K or so miles
Old 12-19-2009, 05:55 PM
That Guy
Techno Duck's Avatar
Not all late cars were 16v, only the S, S2 and 968. Everything else was 8v.
The turbo intake will match up with the intake ports on the head, but the throttle body layout is completely different.
Its a basic swap, all you do is replace the DME and AFM from a late (85.5-87) 944 and are good to go.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-19-2009, 06:33 PM
i see OK! i was thinking all where 16v....i was like uhhhh...ok.......
i wonder how hard it would be to change the throttle setup? i need to find a comparison picture
Old 12-19-2009, 07:07 PM
That Guy
An old picture from my 951, the throttle body angles much differently and the throttle cam is side mounted rather than top mounted like on the n/a. You can probably make it work, but i dont see the reason. Other things to think about are the layout of the vacuum hoses for the ISV and brake booster are completely different. More trouble than its worth i think.
Jon
Old 12-20-2009, 12:50 PM
i was contemplating it while i do some R&D for a supercharger project.
a turbo intake manifold would give more room and fix alot of other issues!
Old 12-20-2009, 05:47 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
The complete air intake is different along with the throttle cable being completely different, the oil dip stick will not fasten down to the turbo manifold - slightly different location and mounting position at top. There are extra ports into the turbo manifold that will have to be dealt with, etc.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 12-20-2009, 10:35 PM
mmm i see, i forgot about the ports....WELL....i guess ill scrap this idea and work with what is already had!
Old 12-21-2009, 12:08 AM
