-   -   16v engine conversion - Ignition control module (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/520248-16v-engine-conversion-ignition-control-module.html)
cjpacitto 01-07-2010 12:29 PM
I'm looking at putting a 16v engine in my 944na. I have found an engine and the seller will provide: Engine, exhaust, wiring harness, DME, AF, Ignition control module, & flywheel. Is there anything else I would need?
2nd question. Does the 944 na have the wiring harness that the ignition control module plugs into or do I need to get that wiring harness as well?
porsche4life 01-07-2010 12:35 PM
I would get the wiring harness too JIC. You might not need all of it but you will need some of it.
Tam Lin 01-08-2010 05:48 AM
I'd get an electronic speedo and I'd look into how you're going to control the heating, as the locations/actuation is different 8v?16v. Those were the PITA when I dropped the 3L into a 924S.
Best
Sean
