cjpacitto's Avatar
16v engine conversion - Ignition control module
I'm looking at putting a 16v engine in my 944na. I have found an engine and the seller will provide: Engine, exhaust, wiring harness, DME, AF, Ignition control module, & flywheel. Is there anything else I would need?
2nd question. Does the 944 na have the wiring harness that the ignition control module plugs into or do I need to get that wiring harness as well?
Old 01-07-2010, 12:29 PM
I would get the wiring harness too JIC. You might not need all of it but you will need some of it.
Old 01-07-2010, 12:35 PM
Tam Lin's Avatar
I'd get an electronic speedo and I'd look into how you're going to control the heating, as the locations/actuation is different 8v?16v. Those were the PITA when I dropped the 3L into a 924S.
Best
Sean
924S 1988 KW3 v3, Wilwood brakes, and a diet. Oh and a 3L 16V drivetrain
Old 01-08-2010, 05:48 AM
