I had a plug heater on an old Ford I once owned. It worked very well and I had instant heat on my way to work. I had it attached to a timer that would turn it on a couple of hours before it was time to drive to work. Engine leaked/burned oil so I'd use 40 wt all year. It would not start in cold weather without the heater. There was never a problem with starting the engine in the cold mornings.
The heater had a sizeable current draw and was inserted in a freeze plug hole. I pulled the dipstick a number of times and the oil was always tepid. The entire engine would be warm to the touch. The oil would be heated indirectly because, though it was in the sump, it had heated metal just above it. Radiative heating plus the conduction into the pan walls is sufficient to warm the oil on nights when the air was still. Eventually, everything became warm.
Trust me, I'm a doctor in matters of heating. |
One can also add a pad type heater to a battery to help with cranking power insead of a cold battery.
Another way of doing a motor heat is go and get 40' or so of plumbers heat tape and wrap the motor with it around and around - warms the oil and water/antifreeze and all. It will not melt or harm any plastic or any thing under the hood - plug it in overnight or put it on a timer. |
I'd move if it got that cold here.
I've been unable to find any discussion about 944 block heaters. Either they don't fit, or people don't have Porsches in cold weather areas. The peel n stick pad heaters...any idea if there's any prep work to apply them? Does the oil pan have to be sanded and smoothed? Does the odd shape of our oil pan make it hard for application? What do you think Doctor Lawrence? :) |
Guys! PO drove my car for many years near the Arctic Circle with a block heather mounted at the back of engine in the freezer knock out lid. It works wonderfully even today in the middle of the country at minus 24 C. Has an outlet for a cabin heather as well but seldom used as cabin heath comes rather quickly with the preheathed engine.
Start-stop is controlled by a timer. Recommended start time is 2-3 hours before use of the car and it fires up is amazeingly fast. Brand: DEFA (Norwegian I guess). Search DEFA and go from there. Good luck! __________________________________________________ Lapponia 944 Na 1984 |
Do you have any pictures of the heater installed? I'm not sure what the freezer knockout lid is.
To install the block heater you first have to pry out the freeze plug (screw drivers, punch, etc.). The block heater usually has a rubber gasket or o-ring and a screw on the front to wedge it in. If you're not comfortable doing this it's pretty low cost to pay a shop. Regarding the oil pan heater. I've never seen a "peel and stick" type. Usually I use the high temp silicone from NAPA and smear it on the silicone pad and/or the oil pan, then just stick it on. I usually hold it tight overnight with a jack (don't use a hydraulic jack because they usually don't hold tight for long). From an earlier post - Yes, I'm speaking from experience. |
+1 AKCJ. Here´s som pictures of my 944/84 heathing installation.
Pic 1: Inlet socket 220 Volt (Earthed of course). Pic 2: Junction between block heather and cabin heather. Pic 3: Block hether just below rear motor lifting ear. Pic 4: Cabin heather socket in front passenger leg space. http://forums.pelicanparts.com/uploa...1263735361.jpg http://forums.pelicanparts.com/uploa...1263735387.jpg http://forums.pelicanparts.com/uploa...1263735406.jpg http://forums.pelicanparts.com/uploa...1263735436.jpg Good Luck SmileWavy _____________________________________ Lapponia 1984 944 NA |
Lapponia,
Interesting to see your install. We're not used to seeing 220 volt power used like that. I've seen the (AC power) cabin heaters but not many people use them here. I don't have any heaters on the 944 - I wouldn't consider driving it here in the winter. Most people with modern cars just use an autostart to warm up the engine and cabin before heading outside. Even better is the heated garage. We're such wimps these days! AKCJ |
