exitwound's Avatar
Engine Block Heaters?
I've done some searching on the multiple 944 forums but can't seem to find a definitive answer regarding block heaters for the 944. Can you get a block heater for a 944? I know that you can't use the magnetic heaters due to the aluminum oil pan, the dipstick heaters don't work efficiently...
I have a really hard time starting my car when it's less than 30F out. Battery has charge, starter turns too slowly though because the oil is so cold. My ISV isn't working yet so keeping it running is hard as well.
I'm trying to find something that would heat up the oil, even just a little bit, before I start the car. Many of the links I've found on the Rennlist forums point to products that don't see to work though on the 944. So..what's out there? Anything?
-Patrick
Black 1986 944
Old 01-12-2010, 10:37 AM
You could buy a magnetic one, then JB Weld it to the block or oil pan. Just a thought....
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-12-2010, 10:42 AM
TSNAPCRACKLEPOP's Avatar
there may be a dipstick heater, and an inline radiator hose heater.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 01-12-2010, 02:44 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
improvise
You might have to roll your own or adapt something off the shelf. The block heaters that are in the coolant system are pretty good. Not sure if I like gluing something to the pan. You basically need a low power heating element like gutter de icers or one of those cup warmers in contact with a major part of the engine. I have used bird bath heaters to good effect on other vehicles. (don't laugh, it worked) you just have to figure out where to put it and how to get it there.
Yea, the dipstick heaters...not so good.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 01-12-2010, 04:00 PM
Redline Racer
HondaDustR's Avatar
An old article in Porsche Panorama (old as in 356 old) suggested just putting an incandescent work light inside the engine compartment and closing the lid. A 100W bulb would probably do it pretty well, maybe up against the head over the exhaust headers.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-12-2010, 09:14 PM
Another way would be to JB Weld a thin steel plate to the pan, then the magnetic heater would cling to the plate.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 01-13-2010, 02:45 AM
exitwound's Avatar
Somebody on Rennlist tried this, said it didn't make enough of a difference, just heated up the headers so they weren't frostbite to the touch.
-Patrick
Black 1986 944
Old 01-13-2010, 04:20 AM
Use Mobil 1, one of the colder grades for the winter. It was originally designed for the Alaskan Oil Pipeline, for the diesel equipment to start at -40 degrees.
Good luck, George Beuselinck
Old 01-13-2010, 05:35 AM
ernie9944's Avatar
Agree with you I try it doesn't work, but those here will they come in 1400w &2000w some as a built in timer .
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-13-2010, 07:05 AM
jpk jpk is offline
Although my Porsche gets the garage and has no problems starting in the cold, my truck sits outsite, sometimes for a couple of weeks at a time in some pretty cold Michigan weather. I've always used semi-synth or full synthetic oil, but the best thing I ever did to ensure it will start is to install an automatic battery charger (battery tender type of thing) which ensures the battery is at 100% when trying to start a cold engine. I wired it up so the plug dangles out the grill, and every time I park it, i simply plug it in. The added benefit is that I'm going on 9 years with the same battery.
btw- even though it sits in the garage, the Porsche gets a battery maintainer as well.
-John
'94 968 Iris Blue
'85.5 944 White - Rally Cross and wrenching practice
'84 944 Gemini Grey (gone, but missed...)
Old 01-13-2010, 07:38 AM
exitwound's Avatar
I have a battery charger. I don't think that the cold battery is the cause of the rough start. I don't think the starter is having problem turning, or receiving the full 12A from the battery. I've had the battery charger on it connected to house power and it still doesn't want to turn over quickly enough. I think it's due to the cold oil. It's a slow crank as if the oil is thick. Once started, it continues to run just fine. I believe there's 10W40 in there now if my memory serves me correctly. I have a rear main seal leak so I don't want to change the oil just yet to synthetic. Perhaps when the weather is warmer and I can do a proper seal fix I'll change it all. For now, I just would like the car to turn over more easily. And I'd like to avoid attaching anything permanent to the oil pan if possible hehe
-Patrick
Black 1986 944
Old 01-13-2010, 08:39 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Try a small electric heater and place it under the motor on floor. Turn it on a couple of hours before starting and the motor and under hood will be toasty.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-13-2010, 09:12 AM
exitwound's Avatar
I thought of that too I don't have a garage and that might be a little dangerous concerning a fire, wouldn't it? Get that heat under the hoses, or on a plastic part. Could spell danger.
-Patrick
Black 1986 944
Old 01-13-2010, 10:39 AM
Under the car
I would guess you have a weak starter or an electrical connection issue if you are sure that your battery is good. These cars really should not have any trouble starting in 30 degrees.
Old 01-13-2010, 11:46 AM
Cars & Coffee Killer
legion's Avatar
Yep, you need to run thinner oil in the winter.
If you run 10W50 in the summer, you should run 0W40 or 0W30 in the winter.
5 liters of VVT fury now
-Chris
Old 01-13-2010, 12:03 PM
exitwound's Avatar
I should change the oil soon. I got the new engine at the Hershey Swap meet in April. Don't think we changed the oil in it yet. Car only put on like 200 miles since then. Can't afford to drive it much Maybe I'll put in some thinner oil in it.
-Patrick
Black 1986 944
Old 01-14-2010, 07:54 AM
AKCJ's Avatar
I can tell you that block heaters (frost plug/freeze plug) work very well. That's basically the standard around here. That being said I don't remember off hand what the freeze plugs look like on our cars - location, size, etc. I'm not going out at 25 below zero to look but someone else may know. If the freeze plug is accessable and you can get the right size, they're pretty easy to install (or cheap to pay someone with a warm garage to install).
Cheap, easy to install, works well - what's not to like?
Another somewhat standard item here is an oil pan heater. They're available at all the auto suppliers around here (even most of the grocery stores here have them). It's just an electric silicone heating pad available in different sizes - dimensions & wattage. You can see examples at padheaters dot com.
Red 83 944
Old 01-15-2010, 02:50 PM
exitwound's Avatar
Peel and stick eh? Interesting.
I dunno what the plug on the 944 block looks like. If it was obvious, i'd think more 944s would have block heaters on these forums. No one seems to have one though.
-Patrick
Black 1986 944
Old 01-15-2010, 03:29 PM
ernie9944's Avatar
PAD HEATERS
Old 01-15-2010, 03:33 PM
exitwound's Avatar
You speaking from experience? Do they work?
-Patrick
Black 1986 944
Old 01-15-2010, 04:17 PM
