Wheel play/ ball joint
Howdy everybody! I recently had my car inspected and it was failed for a bad ball joint. Having said that, I'm not entirely sure that is a correct diagnosis. The wheel has a very small amount of play at the 6 & 12 o'clock positions. I'm really suprised they failed it, as I've had a car with far worse issues pass. Anyways, there is less than 1/16th of an inch of lateral movement at the top and bottom of the tire. I know that is often due to bad ball joints, but I can't feel any play in the ball joint. I've disconected the ball joint from the spindle, and it appears to be tight; I can't feel any play in it. I've checked the wheel bearing as well. What other areas should I check? Are there any other ways to check the ball joint?
All Spooled Up
You need to be feeling the ball joint while someone else is doing the 6-12-push-pull on the wheel. The only other thing besides loose bearings that could cause that play, is worn or bad control arm bushings.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
I recently saw a car that had very loose Strut Camber bolts that gave play similar to bad/loose wheel bearing. The ones at base of strut to Spindal.
Otherwise 6-12 = Wheel bearing or C-Arm ball joints. 3-9 play = Steering rack ball joints.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
Well, I retract my statement. I pulled the ball joints apart and the cups are rubish. Anywho, I guess it's time for a rebuild eh?
I just posted a WTB add for a passenger control arm with a good ball joint. It might be easier to just swap the arm if someone has one they are willing to part with for cheap.
Will program for food
Rennbay has ball joint kits. I would suggest the Track/Performance Ball Joint Kit... I would also suggest replacing both at the same time. If one side is bad the other will be or will be soon.
Click here
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee Last edited by ghnat; 01-12-2010 at 08:01 PM.. Reason: update url |
That's what I've ordered. Hopefully they work.
