justin's Avatar
hatch making noise....
I know there's a kit out there to fix the hatch window when it starts to make the chicken noise when you go over bumps.
Where do I buy it? I think it's when the glass starts to move inside the rubber. Thanks in advance.
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 11-26-2001, 11:15 AM
944pete's Avatar
Question
I've got the same problem. You can hear the wind whistling through it at highway speeds and I noticed a few drops of water on the backrest of the rear seat when I washed the car last. It seems to be worse in colder weather. Is it expensive to fix? (I'm not cheap, just married)
Pete
Old 11-26-2001, 12:32 PM
Smile
Yes there is a kit to repair the hatch. I purchased the kit through www.9xauto.com via an eBay auction. I have yet to install it so cannot verify whether or not the kit works. Although, the seller has sold many of these kits and I don't see any complaints yet. Good luck!
Old 11-26-2001, 01:55 PM
brett25's Avatar
Hi. i had alot of hatch noise also. try shortening the two hatch bolts (by screwing them in a bit more)it will make the hatch seal tighter. that really helped me.
Brett
Old 11-26-2001, 06:45 PM
lambic2000, do the instructions for that kit specify removing the hatch, and then removing the glass in order to re-tape with the micron stuff and re-glue? Or can it be fixed without completely pulling the hatch?
Old 11-27-2001, 07:03 AM
cheap fix
I bought a long reel rubber weather stripping (actually rubber and produced for windows on autos and boats) for under $5.00 at Walmart and laid it in the groove where the hatch actually closes. This solved the wind sound and actually reduced cabin noise considerably at high speeds. BUT, if it's really a glass problem, then you're right to get the kit.
Jake
Old 11-27-2001, 07:09 AM
justin's Avatar
Mine is glass noise,it dosn't leak any water it just squeaks when I hit bumps, it sounds like a bunch of chickens back there......
928 OC member
PCA member
Old 11-27-2001, 10:18 AM
Bob's944's Avatar
Send a message via AIM to Bob's944
Porsche Crest
I had some noises that turned out to be some loose hardware on the rear wiper motor. Tightened and lubed things up... noise gone. Now when I have a noise back there, it's that I didn't close the hatch with both hands firm enuf and the drivers side is not locked in. I stop right away and do it right. All in all, mine seems to be in good shape as far as the rubber, shocks and hinges go... although my inside hatch release only works once inna while, so I hardly use it anymore.
Old 11-27-2001, 10:30 AM
justin's Avatar
I have no rear wiper.. and I shut it real well it's benn doing this more and morre aver the past few months.
928 OC member
PCA member
Old 11-27-2001, 10:43 AM
Smile
Over the years the glass will actually separate from the frame. When this happens, the hatch will squeak and continue to squeak until the glass is re-glued to the frame. The instructions are pretty self explanatory and removing the hatch from the car is not necessary.
Old 11-27-2001, 12:53 PM
justin's Avatar
I think I will order it soon.
928 OC member
PCA member
Old 11-27-2001, 02:48 PM
