-   -   Air filter for S2 Engine in non-turbo front end. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/524087-air-filter-s2-engine-non-turbo-front-end.html)
disgraceland 01-30-2010 03:10 PM
I've got an 89 with a non-turbo front end with an S2 engine installed and am trying to work out an air filter solution. I'm concerned that a stock S2 filter setup is not going to like squeezing in under the normal front end header panel. Anyone have any experience with this or suggestions? Thanks.
ernie9944 01-30-2010 04:08 PM
This is a 968 motor install in 924s I believe but not sure this set-up could apply in your case .http://forums.pelicanparts.com/uploa...1264896345.jpg
josephsc 01-30-2010 11:46 PM
Long time ago (maybe 6 years?) a fellow over on Rennlist stuffed an S2 motor into an NA (your setup) -- and his solution was to actually use a nose panel from a 931 (924 turbo). It'll require some cutting on the underside of the panel, but he reported that the S2 airbox fits underneath the 931 nose panel, but not under a 944 nose panel.
I never got around to trying that for my 944, before I grenaded the 968 motor, however....
The cone airfilter solution requires care -- notice how dangerously close the headlight linkage is to the filter in the photo above. Mine was like that, and would cut holes into the filter.
disgraceland 01-31-2010 08:17 AM
No AFM on that setup?
ernie9944 01-31-2010 10:29 AM
The pic was just an exemple but I realize now "sorry" that it won't work on your car because of your AFM maybe your only choice will be to get a 951 front end or with the nose panel of a 931 as mention by Josephsc will keep looking for you .:)
disgraceland 02-02-2010 11:05 AM
I pulled the header panel off of an 84:
http://hphotos-snc3.fbcdn.net/http:/..._3321401_n.jpg
if an 89 looks anything like this then some sort of other setup is going to be necessary, as the front end of an S2 is significantly different:http://hphotos-snc3.fbcdn.net/hs199...._2752759_n.jpg
Anyone tried anything like this before or have any suggestions? Thanks.
porsche4life 02-02-2010 11:19 AM
I would assume the 89 is more similar to my '86....
http://forums.pelicanparts.com/uploa...1265138269.jpg
http://forums.pelicanparts.com/uploa...1265138342.jpg
Techno Duck 02-02-2010 05:49 PM
All '85.5 up cars (8v, turbo and 16v) had the same front clip. The big difference with stuffing either the S2 airfilter or turbo intercooler in that spot is the nose panel is larger for the S2 and 951. Also as you can see in Sidney's pictures, the upper radiator support is much different, allowing the plumbing to pass through. So yes, if using a '85.5+ tub you can use the S2 style airbox, but you need the turbo / S2 front end to make it fit. The difference there is the nose panel, bumper cover, bumper bar, front fenders, headlight covers and front headlight bezels.
The pre '85 cars all had what is in disgraceland's first picture.
disgraceland 02-02-2010 06:01 PM
Anyone know of an aftermarket setup that might work without replacing the front end?
ernie9944 02-03-2010 07:02 AM
Why would somebody bother the make an after market set up since how many would you think they,ll sell ,if someone had the solution on this forum they would had came up with it .You can keep looking on some other forums but it migth take quiet a while to find the solution to your problem, you'll probably get the same answer (951 or S2 front end) good luck in your search.
http://forums.pelicanparts.com/suppo...eys/yltype.gif
