Banned
My clutch findings
I started yesturday night, took acouple hours to drop the trans and about an hour for the exhaust and torque tube. I started the bellhousing this morning. the PO only had two bellhousing bolts in. He didn't even bother bolting the left side down. But now for the fun, A BENT FORK!!!!!!!!!!!!
Old 01-31-2010, 07:46 AM
levi
The clutch fork?
1978 911sc cpe
1986 944 N/A sold to pelican
1965 series 2a 88 landrover sold
1964 series 2a 88 landrover sold
1988 944 white. sold
Old 01-31-2010, 08:06 AM
Toofah King Bad
Rasta Monsta's Avatar
Why the sob? Found your problem, and it's a cheap scrapyard fix.
Go Kid!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-31-2010, 08:09 AM
Banned
Originally Posted by landrover88 View Post
The clutch fork?
yepp!!
I'm going to take the PP and flywheel off to see what else might be awry.
Old 01-31-2010, 08:17 AM
Banned
I noticed that there is some damage to the PP fingers from the throw out bearing, and the TO bearing has about 2mm of play in all directions. I'm going to replace the TO with a new one, but what do you guys think about the PP?
Old 01-31-2010, 11:42 AM
TSNAPCRACKLEPOP's Avatar
well, while your are in there, new plate for sure
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 01-31-2010, 12:53 PM
your average wrencher...
call up KEP....
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 01-31-2010, 04:25 PM
Banned
I got in my new kit, Is there supposed to be play between the PP and TO bearing.
Old 02-02-2010, 03:16 PM
in the released state, there should be some play, just a little, when the clutch pedal is released/ is out. this is your clutch pedal play. when the clutch is DISENGAGED the TO bearing should not be riding on the PP. otherwise it would wear out much sooner.When the clutch pedal is depressed, it contacts the PP, and compresses the springs so you can shift.
You might want to search here for play and clutch arm because i think there is a bushing that sometimes fails on the arm shaft.....seems like i read about it a couple times. if your TO bearing shaft seems tight and no metal particles, i would go ahead.
Old 02-06-2010, 09:48 AM
All Spooled Up
Are you sure you don't mean, ENGAGED (no pressure on the pedal)?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 02-06-2010, 07:18 PM
pedal disengaged, clutch engaged. pedal engaged, clutch disengaged.
Old 02-10-2010, 07:24 AM
