944 hatch problem
Hi all - new member here from, you guessed it, London. Pic of my Porsche below by way of introduction, and very well it's done me too for the last two and a half years. I did have one issue you might be able to help me with.
The left rear hatch pin no longer locks in place. Peering into the hole it looks like an element of the locking ring has come adrift, which would explain the lack of lockability. Has anyone else experienced this? And is it possible to replace the whole 'female' element of the lock, which looks like it can be unbolted from the rear panel. With all these damn speed bumps here in London, driving it has to be putting pressure on the other pin. Thanks hugely. http://i160.photobucket.com/albums/t...x/DSC_7543.jpg |
The amount of dirt and debris that collects in that part will scare you. The lower catch is easy to remove with two nuts each side. Clean it out and lube it and reinstall. I have replacements if yours is broken
http://forums.pelicanparts.com/uploa...1265662381.jpg Remove #27 and #26 will fall into your hand when you move the release stem. |
are the two halves of the lock ring stuck in the "in" position? if so, then it's just dirt. just clean it out like griffin suggested.
if the two halves are moving freely by hand then u need to adjust the pin so it reaches in more. it's a 13mm wrench if i remember correctly. |
Thanks for the replies. The locking ring is permanently pushed out, so it might just be grime. I'll have a go at (carefully) dismantling it to see if it's stuck. Otherwise it's new-part time.
Oh and Griffin, do you have a larger version of that picture? Much appreciated if you could send it/link it to figure out all the bits. Thanks
This vendor has every used part on earth and the best exploded diagrams - Shameless plug :D He helped tons of Porsche cars back from the dead. I try to buy from our host for all new parts he carries but know Robert has a huge inventory of the hard to find used stuff.
dC AutomotiveOver 140,000 square feet of new and used Porsche parts |
Thanks for that, but scary shipping costs. Rear lock $35 - shipping $40! Think I'll use the exploded diagram to guide myself to fix it.
Get in the back, pull the carpet back and you will see the two latches... they are held on with 10mm nuts.... Pull those nuts off and you will have the latches... My best advice would be to take them off the connecting rods and clean them in hot soapy water.... Get them functioning properly and then lube them back up and reinstall...
if you over tighten the 2 10mm nuts, Ive found it pinches the locking mech. and will give you trouble.
Great - thanks for all that. I'll have a bash on the weekend and let you know how it pans out.
Excellent. All it took to release the locking ring was to loosen the 10mm nuts. A bit of WD40, tighten the nuts and voila. Very useful 10 mins that. Thanks for all your help guys
Welcome on Pelican Londonlux ,as you can see hold bunch of very helpful peoples here,is your car Platinum Metz if so I had an 83 same color if you click on my garage you'll see old faithful, could you send use more pics if you got some. http://forums.pelicanparts.com/support/smileys/wat6.gif
Same colour as your old car - for some reason I think it's Sahara Beige (best name for gold I've ever heard). Interesting mods on yours, but you Americans really do lose out on licence plate location don't you!
Another pic of mine - taken outside my local 'under the arches' Porsche specialist in Vauxhall, London http://i160.photobucket.com/albums/t...x/DSC_7536.jpg |
Or you could just be a rebel and skip the front plate ;)
Welcome to the board! I'll have to give this fix a go in the spring. Nice looking car! |
Yeah, removing the front plate isn't an option we've got. How would those forward facing speed cameras pick you up!
http://forums.pelicanparts.com/uploa...1266157617.jpg |
I'd love to be able to do that! But the UK is super tough on numberplates - you even get pulled over and fined if the numbers or letters are spaced wrong (which some people do to make the plate spell something) or even are written in the wrong font.
But at least the front and rear are designed for the long Euro rectangular plate - even if we Britishers suffered with initial right-hand-drive penny pinching like no switchover for the front and rear wipers and the bonnet release. |
| All times are GMT -8. The time now is 05:58 AM. |
