DP944's Avatar
rebuilt updated waterpump differences
please someone explain to me the difference between these two pumps.
Pelican Parts - Product Information: R-106-021-01X
Pelican Parts - Product Information: R-106-021-04X
is the only difference the fact that one comes with a belt guard and the other doesnt? if i already have the belt guard from my old pump should i get the first one without it?
"I couldn't find the sports car of my dreams, so I built it myself." Dr. Ferdinand Porsche
Old 02-15-2010, 10:19 PM
DP944's Avatar
Pelican Parts - Product Information: 944-105-241-04-M40
do i need this?
Old 02-15-2010, 10:26 PM
DP944's Avatar
or this
Pelican Parts - Product Information: 944-105-027-04-M40
if my motor already has these rollers in good shape why replace them, unless the bearing fails correct?
Old 02-15-2010, 10:29 PM
smokin_944's Avatar
DP944, the 2 Pelican Parts product info points out to early pump (-01X) and late pump (-04X). I always replace all the rollers while I'm in there because the job is a PITA and I don't want to go back in there for another 35k or so. I also change the wp every second belt and roller change. Some may consider this overkill but I have not ever been stranded on the road with my car in all the years I've owned it. The call is yours.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 02-16-2010, 06:02 AM
early doesn't have a belt guard plate. late does.
iirc, if u upgrade from an early to a late, u need the late idler roller.
of course if u stay early, u don't need the roller unless yours are shot.
Old 02-16-2010, 10:29 AM
smokin_944's Avatar
Correct. That is why he should upgrade to a new water pump (turbo pump) 951 106 021 10 which is the correct upgrade to the early water pump. It has correct rollers and belt guard included but requires a block off plate.
Old 02-16-2010, 12:44 PM
Schumi's Avatar
Bruce's site has good pictures dealing with old/new waterpump styles:
Updated Waterpump
M
Old 02-16-2010, 01:05 PM
