-   -   Introduction (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/531735-introduction.html)
saifhaq 03-17-2010 09:25 PM
Introduction
Hi,
Been lurking around these forums for a while and felt I should introduce myself. I picked up an '86 944 N/A about 7 months ago with 48,xxx miles. Its all stock. Didn't get a chance to do much with the car since I put it away for winter soon after i got it.
So far, I've changed the brake lines and put new tires on. Planning on changing the timing belt this spring (was changed 3000 miles ago by PO, but that was 4 years ago) and update the radio.
Also, the rear license place was relocated to the rear bumper (light panel installed by original owner between the tail lights) and I'm looking for ways to illuminate the plate, as it is required by law.
looneybin 03-17-2010 09:48 PM
welcome to the fray
If you haven't already seen it, take a look over the clarks-garage site, lots of helpful info there
as well as the brain trust here
AA_Ezra 03-18-2010 01:19 AM
Welcome, I too have the rear center reflector light thingy. I gave up on trying to eliminate the plate and luckly have never had a problem. I bet a modified licens plate cover the kind dealers put on new cars would work. Perhaps a thin led neon bar used in r/c underbody kits would work on the top of the plate. Or just relocate it back to stock
looneybin 03-18-2010 06:52 PM
they do make a lighted plate frame, check in the ricer aisle of your auto parts house
Cocacolakidd 03-18-2010 07:29 PM
I have seen many of the lighted license frames on eBay (and that can be pronounced as Evilbay also - ha ha)
Welcome to the Pelican nest here
saifhaq 03-18-2010 11:12 PM
Thanks for the welcome SmileWavy
I've come across the neon and the lighted ricer plate frames, and i'm not to keen on going that route. Looking for a subtle black frame with maybe two led's in the frame.
Grandad#3 03-19-2010 09:20 AM
WELCOM TO THE FORUM. You might check out Pep Boys for a light bar that attachés to the top of the license plate. The other option is the Ricer frame and paint it black.
Cheers,
Larry
saifhaq 03-19-2010 03:03 PM
BTW, here are few pics i had taken a while back...
http://farm3.static.flickr.com/2586/...603786e192.jpg
http://farm3.static.flickr.com/2530/...d57787e207.jpg
http://farm4.static.flickr.com/3454/...cddca4b9c4.jpg
http://farm3.static.flickr.com/2429/...9f83bef533.jpg
http://farm3.static.flickr.com/2664/...bc5db712e1.jpg
http://farm3.static.flickr.com/2628/...0254bfe7e3.jpg
ernie9944 03-19-2010 04:00 PM
Welcome to Pelican love your car seem to be in very very good shape for an 88 ,is it a Canadian car I'm drooling over your sport seats ,seen your new stereo set up on RL you did a good job look sharp.You should send that post over here very helpful infos.http://forums.pelicanparts.com/suppo...ys/elklaff.gif
saifhaq 03-19-2010 04:27 PM
Thanks Ernie. It's actually an '86.
Will be putting that post up here tonight.
944Lover 03-19-2010 04:29 PM
Your car is beautiful! lol I have an 86' as well, but the drivers seat is ripped and the dash is cracked and I need to fix my heat/ac (it doesnt work)
saifhaq 03-19-2010 08:03 PM
The heat wasn't working when i got my car either. It turned out to be the fuse.
