saifhaq's Avatar
Introduction
Hi,
Been lurking around these forums for a while and felt I should introduce myself. I picked up an '86 944 N/A about 7 months ago with 48,xxx miles. Its all stock. Didn't get a chance to do much with the car since I put it away for winter soon after i got it.
So far, I've changed the brake lines and put new tires on. Planning on changing the timing belt this spring (was changed 3000 miles ago by PO, but that was 4 years ago) and update the radio.
Also, the rear license place was relocated to the rear bumper (light panel installed by original owner between the tail lights) and I'm looking for ways to illuminate the plate, as it is required by law.
Old 03-17-2010, 09:25 PM
unindicted co-conspirator
looneybin's Avatar
welcome to the fray
If you haven't already seen it, take a look over the clarks-garage site, lots of helpful info there
as well as the brain trust here
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 03-17-2010, 09:48 PM
Welcome, I too have the rear center reflector light thingy. I gave up on trying to eliminate the plate and luckly have never had a problem. I bet a modified licens plate cover the kind dealers put on new cars would work. Perhaps a thin led neon bar used in r/c underbody kits would work on the top of the plate. Or just relocate it back to stock
Old 03-18-2010, 01:19 AM
looneybin's Avatar
they do make a lighted plate frame, check in the ricer aisle of your auto parts house
Old 03-18-2010, 06:52 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
I have seen many of the lighted license frames on eBay (and that can be pronounced as Evilbay also - ha ha)
Welcome to the Pelican nest here
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 03-18-2010, 07:29 PM
saifhaq's Avatar
Thanks for the welcome
I've come across the neon and the lighted ricer plate frames, and i'm not to keen on going that route. Looking for a subtle black frame with maybe two led's in the frame.
Old 03-18-2010, 11:12 PM
WELCOM TO THE FORUM. You might check out Pep Boys for a light bar that attachés to the top of the license plate. The other option is the Ricer frame and paint it black.
Cheers,
Larry
Old 03-19-2010, 09:20 AM
saifhaq's Avatar
BTW, here are few pics i had taken a while back...
Old 03-19-2010, 03:03 PM
ernie9944's Avatar
Welcome to Pelican love your car seem to be in very very good shape for an 88 ,is it a Canadian car I'm drooling over your sport seats ,seen your new stereo set up on RL you did a good job look sharp.You should send that post over here very helpful infos.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-19-2010, 04:00 PM
saifhaq's Avatar
Thanks Ernie. It's actually an '86.
Will be putting that post up here tonight.
Old 03-19-2010, 04:27 PM
Your car is beautiful! lol I have an 86' as well, but the drivers seat is ripped and the dash is cracked and I need to fix my heat/ac (it doesnt work)
Old 03-19-2010, 04:29 PM
saifhaq's Avatar
The heat wasn't working when i got my car either. It turned out to be the fuse.
Old 03-19-2010, 08:03 PM
