Headlight Washer leak
I fixed a crack in the washer fluid tank today, filled it up and fluid was pouring out of the front bumper. I'm assuming that the hose to the nozzle is cracked/broken. Is it easy to get to this connection? If so, how? Any help would be appreciated.
Mark '83 Porsche 944 NA '90 Porsche 944 S2 |
where from the bumper? by fixing the crack did you crack it somewhere else possibly, the headlight washer should be a open flow until you use the switch and turn the pump.
1983 944 Guards Red (87' Implant Complete) |
From what I could see from under the car, no water was coming from the tank, but it was pouring from inside the bumper. There's a hose that comes from the pump on the bottom of the tank into the bumper.
If got w/w liquid leaking in the pumper this is no brainer the hose connecting to h/w/ noozle is probably crack & leaking or loose at the noozle ,it did not leak before because you had a crack in your winshield water tank & no pressure going in the h/w noozle.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
sure, but how do I fix it? How do i get to the nozzles to replace the hose?
