Does this Look right? Coolant in block valleys.
Ordered my head gasket set from pelican and doing some prep for the head replace.
Is there supposed to be coolant down in the valleys around the cylinders? I am thinking if there is NOT supposed to be, it got in there when we took the head off and it still had some coolant in it.
Also, is a early 2.5 944 head with a bent valve worth anything? Should I just buy a new valve and install it for $25 bucks and then sell the head?
Thanks again, this forum is invaluable.
Zach.
Old 04-17-2010, 08:26 AM
Rod Schneider's Avatar
That is exactly where the coolant circulates! Very normal!
Rod Schneider
Ball Ground, GA
88 928S4, 87 Corvette,
88 Fiero GT, 16 Mustang EcoBoost
Old 04-17-2010, 11:02 AM
+1 ^ its normal, if you want to get it all out there is a drain plug on the block you can remove and let it drain out completely. its located next to the oil cooler or oil pressure sender if yours has been removed
1983 944 Guards Red (87' Implant Complete)
Old 04-17-2010, 11:04 AM
If all you are going to do is buy a replacement valve for the head, its not worth anymore than before. Needs a full valve job before it can be installed, plus seals and possibly valve guides if it was truly bent.
Is the valve visually bent, or does it just not come out of the guide?
1983 944 - project mode
2002 Ford F150 - every other daily driver
1976 Honda Goldwing - the other days
Old 04-17-2010, 11:10 AM
The valve is broken on the shaft by the head of the valve.
Old 04-17-2010, 11:24 AM
Def don't buy a replacement valve unless its a courtesy to the guy you are selling to. And some people would go as far as saying you shouldn't replace just a single valve on a used head.
Old 04-17-2010, 11:38 AM
Proprietoristicly Refined
John_AZ's Avatar
The firewall engine galley, rear, bottom-----------is where you may find silver sludge. Drain the coolant and clean up the gally bottoms.
Also, check your lifters:
http://www.benms.com/944lifter.html
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-17-2010, 01:09 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
broken head
There is someone on the board that collects old heads for the cause and rebuilds them. I don't think 1 bad valve will dissuade him. Not sure if it is worth a whole lot though. I think he sells the reman heads to people in your situation.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 04-17-2010, 02:44 PM
SolReaver's Avatar
yep!
Yea, i wasn't imagining things...It is "many944s" and this thread gives the details. Talk to this guy as he knows a lot more about it than I do.
Anyone have a 8v NA head with bent valves?
Old 04-17-2010, 02:51 PM
Under the car
I haven't been able to get in contact with many944's for a long time. I have a head I tried to get to him and just quit hearing from him. I still have the head and just about can't give it away. Its not even bad... I just don't want it.
Old 04-17-2010, 08:41 PM
SolReaver's Avatar
odd...
That IS strange....His last logon date was in August of LAST year. I hope he is doing well. Hopefully we can get a response from him sometime reasonably soon. When it comes to the down and dirty questions about heads, he usually has the answer.
Does anyone else have info on Many944s or a good reputable re builder who could use the core? I can ask my favorite machinist, but, I am not sure he wants to expand into this niche market. And I don't have the equipment to do it right.
Old 04-17-2010, 09:07 PM
