Send a message via ICQ to GAKFU Send a message via Yahoo to GAKFU
2 Battery issues
My 944 has sat around most of the time for the past five years. So most of the things i have found electrically is corrosion. But now i am down to a NEW battery just bought last week. I am having two issues. One is that i am worried that my alternator is not recharging. while sitting and running it is kicking 13.78v at the battery. If i turn everything on the voltage goes down to 13.30v. This seems low to me. Also while i was driving it during the day over the weekend the voltage gauge went below the 12v almost like it was only 10v.
The other problem is that i let the car sit for a few days and when i went out to start it, it was dead. I wondering if the battery drain is a bad starter? As anyone else seen this?
Old 04-14-2010, 05:43 PM
Rex Karrs's Avatar
Mine will drain a new battery in 4-5 days if it just sits.
Old 04-14-2010, 08:49 PM
sounds like you have something grounding out somewhere in the car. if its one of the major ones its easy to find, just pull one fuse at a time using a voltmeter to find the culprit
1983 944 Guards Red (87' Implant Complete)
Old 04-14-2010, 08:54 PM
voltage tonight
when i got home tonight i checked the battery and it had 11.48v on it.
Old 04-15-2010, 04:22 PM
85Porsche944's Avatar
I would replace both the alternator and the battery at the same time, clean all of the ground connections to the chassis and drivetrain, and I agree with above in checking for ground shorts.
Old 04-15-2010, 04:42 PM
found it
Well I found the short. It is the switch on the key lock for the rear hatch. Amazing that little switch drained the battery dry in two days.
Old 04-18-2010, 06:07 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
The rear hatch was also an issue for mine; not only was it draining the battery, it was setting off my (aftermarket) alarm at random times.
Figured it out, and fixed the problem. No more dead battery/angry neighbors.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 04-18-2010, 08:07 PM
can you check this by pulling each fuse, and sticking the meter in the fuse cavity, if you get a dead reading then you know where to check?
Old 04-21-2010, 12:39 PM
