mfischer78223's Avatar
Best way to remove elec sunroof that wont open
Ok, I got an 85/NA that has power sunroof that wont open. Changed switch and relay still nothing. Can anyone tell me where to look next? How can I check to see if the motor is still good and how can I remove this to replace all the latches on it?
Thanks!
Old 04-21-2010, 12:05 PM
Made in Flacht
jacksd3's Avatar
clarks garage has a good procedure for this. The plastic gears usually shear before anything else gets damaged. They are cheap and easy to replace. So is the motor which is behind the carpet on the left side of the rear trunk.
1988 944S
2001 Boxster S Seal Grey, M030, PSM
2003 Ford F-350 Dually 6.0 litre Turbo Diesel - You think YOU got torque
1995 International 9200 Road Tractor 11 Litre Single Axle Daycab Eaton Super 10 Tranny
Old 04-21-2010, 12:35 PM
JoshB's Avatar
You can manually open the sunroof - there should be a little wrench Porsche provided to do that mounted to your sunroof motor.
89 944 - Alpine white/blue, Focus 9 DME and MAF, MSDS headers
Old 04-21-2010, 12:36 PM
