944paige
Send a message via Yahoo to 911paige
Unhappy PROBLEM ? transmission, linkage or slave
Hi i have a 1980 924 turbo that i am bringing back to life after sitting for ? years i have the car running changed the water pump and timing belt plus a few other parts. my problem is when i try to engage the clutch in first gear it grinds when i place it 2nd or any other gear no grind even reverse no grind i haven't driven the car out of the driveway so i'm not sure what it would do. do you think this is a slave cylinder problem an adjustment, or a transmission problem BTW the trans has been changed to a 944 transmission by the P.O no dogleg or snail type. any clues?
Old 05-06-2010, 08:02 AM
944paige
bump ... for some one that may have had the same problem...what did you do?
Old 05-07-2010, 06:42 AM
Feelin' Solexy
Tishabet's Avatar
First things first... is there lube in the transmission?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 05-07-2010, 09:07 AM
924RACR's Avatar
Wouldn't hurt to do a full, good bleed on the clutch hydraulics... that's at least free...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 05-07-2010, 09:43 AM
944paige
will check on that...thanks.
Old 05-07-2010, 07:28 PM
sounds like a syncro is worn....specially as u can get all the other gears easily....just get that replaced
Old 05-09-2010, 10:38 AM
944paige
hi thanks is this job difficult to do if i use ramps and jack stands .... can an average joe do this job or does it have to be brought into a shop. or can they be accessed thru the shifter. or is it in the rear where the transmision is located ?
Old 05-09-2010, 11:29 AM
Hi, if you are talking about the syncro you will have to pull the transaxle and have someone take it apart for a rebuild. You could always find a good used working transaxle and put it in. I have never owned a 924 but believe the transaxles looked like the 944 na at some point but are differentMaybe only a 4 speed and not as beefy. You mentioned that you thought that you had a 944 transaxle in and this may not be the case. ?
Old 05-09-2010, 11:38 AM
944paige
thanks ... yes the car does not have the original transaxale it was changed by the p.o ... so if it is the syncros then it has to be dropped fixed and then reinstalled. or pick up a used working transaxale and swap them out? o.k
Old 05-09-2010, 11:53 AM
its much easier and cheaper to buy a used working transaxle and install it, plus you can rebuild the one in the car and have a spare around
1982 guards red 944 with 250lb lowering springs, Konis in all four corners, Lexus LS430 front brakes, and 86 turbo front brakes on rear
Old 05-09-2010, 12:23 PM
