-   -   968 caster block upgrade (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/541796-968-caster-block-upgrade.html)
smokin_944 05-11-2010 05:24 AM
I have looked over my suspension and would like to upgrade the control arm inner rear mount. Does anyone know if the 968 upgrade (951.341.023.01 M260)fits series 1 cars? TIA
mistertate 05-11-2010 09:15 AM
Pretty sure an aftermarket company makes a Delrin or PU version for the early cars that will be cheaper..
Rasta Monsta 05-11-2010 09:19 AM
Methinks the 968 units are for Al arms only. You might consider Prothane poly bushings. . .$25 will refresh all bushings on both sides (after you enjoy the heck out of removing the factory rear).
rasta
P.S. You are looking for Prothane Rabbit/Golf Mark I
smokin_944 05-12-2010 06:16 AM
I'm doing the prothane bushings Rasta, just wanted to clean up the mushy rubber bushing in the control arm inner rear mount. What about Fastech? Anyone know about them?
Rasta Monsta 05-12-2010 07:54 AM
Hmm, not following. The Prothane set comes with a poly bushing for the rear "castor" mount.
smokin_944 05-16-2010 07:51 AM
What do I use at the front of the control arm?
