smokin_944's Avatar
968 caster block upgrade
I have looked over my suspension and would like to upgrade the control arm inner rear mount. Does anyone know if the 968 upgrade (951.341.023.01 M260)fits series 1 cars? TIA
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 05-11-2010, 05:24 AM
mistertate's Avatar
Pretty sure an aftermarket company makes a Delrin or PU version for the early cars that will be cheaper..
dude
Old 05-11-2010, 09:15 AM
Toofah King Bad
Rasta Monsta's Avatar
Methinks the 968 units are for Al arms only. You might consider Prothane poly bushings. . .$25 will refresh all bushings on both sides (after you enjoy the heck out of removing the factory rear).
rasta
P.S. You are looking for Prothane Rabbit/Golf Mark I
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 05-11-2010, 09:19 AM
smokin_944's Avatar
I'm doing the prothane bushings Rasta, just wanted to clean up the mushy rubber bushing in the control arm inner rear mount. What about Fastech? Anyone know about them?
Old 05-12-2010, 06:16 AM
Toofah King Bad
Hmm, not following. The Prothane set comes with a poly bushing for the rear "castor" mount.
Old 05-12-2010, 07:54 AM
smokin_944's Avatar
What do I use at the front of the control arm?
Old 05-16-2010, 07:51 AM
