ewalt98's Avatar
Carpet heel pad replacement
My heel pad (the pad your right foot rests on while driving) has a hole worn in right where my heel sit. In fact, it is worn right through the carpet and padding to the floor pan. The rest of the carpeting is in great condition, so I started to look into replacing just the pad, but I haven't been able to find one or an example of someone else trying this.
I will probably just get some mats to cover it, but I also thought of buying some plastic mats from the local auto store, removing my worn pad, then cutting and fitting a section from the new pad to fit.
Has anyone done this? Can you buy just the pad?
Eric
1985.5 NA
Old 06-03-2010, 06:39 AM
ernie9944's Avatar
^^You can make your own foot rest like I did out of an alluminum plate & paint it the colour you want or buy one there not that expensive. "just a suggestion"
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 06-03-2010, 07:15 AM
Under the car
I don't think that is where he was talking about. Is that where your heel sits?
I think he means near the gas pedal.
Old 06-03-2010, 08:49 AM
Porch's Avatar
^ agreed.
I would take the carpet out and take it to an upholstery shop. It could probably be done pretty easily but it would need to be sewn to the carpet with a heavy-duty sewing machine.
~Chris
1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear
1993 Jeep Cherokee - 3" Lift, 30" tires
Old 06-03-2010, 09:24 AM
ernie9944's Avatar
Matthewb____ my mistake I got confuse here I know what you are talking about now he will have to strip the carpet out to fix that, quiet a job.
Old 06-03-2010, 05:15 PM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Ernie...
Fess up.. You were just showing off your new pedals..Huh?
They do look good though..
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-03-2010, 07:09 PM
ernie9944's Avatar
Originally Posted by Gordon Rankin View Post
Ernie...
NOooooo those are old pedals been in there for at least 8 years ,change the color when I sold the car last summer.
Old 06-03-2010, 07:18 PM
ewalt98's Avatar
I guess I will just get aluminum pedals and forget the heel pad!
Old 06-03-2010, 09:29 PM
