Question conversion labor question
How many hours of labor do you think would go into a 944 NA to 944 Turbo conversion? Is this complete, or to make it work would I have to do something to the transmission, exhaust, etc...? I'm thinking about making a deal with someone, and here's what he has included:
newly(0 hours) rebuild complete 944 turbo engine. comes
with....
computer and wiring harness
new crankshaft and new bearings and seals all around. Every thing internal
was cleaned up to spotless shine.
pistons and NEW OEM rods with new rings
head has been rebuild and has wide fire gasket put on.
rebuilt fresh k26/6 turbo
exhaust manifold update no cracks for quick boost
intake manifold with with throttle body and TPS
complete fuel injection
new timimg and balace shaft belts with there rollers
the flywheel with a complete sachs sports clutch.
intercooler with pipes
exhaust crossover pipe, rebuild wastegate.
power steering pump, almost new a/c compressor
almost new radiator, new turbo water pump
stock air filter intake
Old 12-13-2001, 12:53 PM
There has been one or two threads about this.
Basically it's like this; if you have to pay someone to do it, you can't afford it. It's cheaper to sell yours and buy a real 951.
Expect lots of replies to this thread.........
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-13-2001, 01:15 PM
if i was to go through with this, what do you think would be a good price for all that stuff listed above?
Old 12-13-2001, 01:34 PM
ok, as you are obviously not go to listen;
Figure on 20 - 30 hours of labor at your local shop rate.
The radiator won't fit as it's too deep, you have to change the lower support panel.
The intercooler mounts have to be made up and the front inner nose panel might need 'modifying'
The whole exhaust is different so you will need that.
The wiring for the turbo water pump has to be installed.
etc, etc, etc
so, say 30 hours at $60 ph = $1800.00
allow for parts you need = 300.00
so we are up to $2100.00
You can buy a real 951 for $6000 or less
so the engine and all the parts has to be less than $1900 to be even slightly near reasonable. And you end up with something that has the wrong transmission, brakes, suspension etc....
Hmmmmmmm
Old 12-13-2001, 01:51 PM
thanks you cleared that idea right up for me
Old 12-13-2001, 02:02 PM
wolfrpi's Avatar
Do yourself a favor and don't waste memory on your brain's hardrive even thinking about it. Just buy a 951 if you want one.
Erick
Old 12-13-2001, 02:14 PM
I would either buy a 951 or buy the Speedforce Racing supercharger if I were to do it again from scratch.
Old 01-23-2002, 09:28 PM
