Timing belt quick question before starting
Okay...
So everything is back together. before I start it last questions to confirm my timing
cam shaft (front of car) white line on pulley is lined up with timing mark on cam housing
Piston number one is all the way at the top
Back of car right behind the intake manifold I look through the opening and the WHITE line is lined up with the nipple in the bell housing... (this is from the top of the car not the bottom)
Please confirm oh Porsche GURUS
Old 05-21-2010, 11:27 AM
That Guy
Techno Duck's Avatar
Not sure what you mean by nipple on bell housing..but if you can see the OT mark on the flywheel and the line on the flywheel is lined up with the tab hanging off the bellhousing window you should be good. You can verify by checking the notch on the flywheel is lined up with bellhousing also..this is visible from under the car.
If you are paranoid, turn the engine over by hand a few times with the plugs out. It should spin over fairly easily with just resistance from the cam pushing down on the valve springs.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-21-2010, 11:46 AM
yarfk
kfray's Avatar
That is correct how about the 2 balance shaft alinements?
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
thanks guys...
The balance shafts I am not so sure of... I believe they are timed properly. I marked them before pulling the belt and then just slapped it back on.
I have not seen an ot mark on the flywheel just a big white line.... this is an automatic just incase that makes a difference...
IF it is wrong and I start the car what will happen.
Old 05-21-2010, 12:19 PM
Aufenbahn's Avatar
Clark's has best write-up, with drawings, etc.
Old 05-21-2010, 12:20 PM
That Guy
If the timing is off considerably you will bend valves. If the balance shafts are off, it will just vibrate very badly.
This is why i recommend spinning it over by hand if your not sure, this will rule out crunched valves as being a problem .
Jon
Old 05-21-2010, 12:25 PM
Thanks guys... I am about to pull the plugs and turn it over I will post results in 5 minutes
Old 05-21-2010, 12:28 PM
alright... it turns real easy
should I be good
Old 05-21-2010, 12:32 PM
BS belt. depending on what year the car is, it's possible to put the BS pulley's on wrong. the BS pulley have two keyways.
the upper BS pulley should be installed so that the key is lined up to the O mark (over)
the lower BS pulley should be installed so that the key is lined up with the U mark (under)
it's possible that your pulleys don't have one of the marks. so u'll have to use elimination
Old 05-21-2010, 01:16 PM
I am somewhat confused by this response...
We did not replace the pulleys.
However... problem... No starting... lol
I have air, spark and fuel.
How do I know if I was a hundred degrees off on my timing belt install.
Old 05-21-2010, 03:10 PM
ah...well i didn't know that. pulleys are kinda normally part of a tb/wp job.
so u smell fuel and you can see the plug spark? that eliminates speed/ref sensors as issue.
i thought u said u had the marks all lined up? unless u had the head off, it's impossible for u to be 180degrees off.
reset yer flywheel and reverify cam gear timing.
Old 05-21-2010, 08:03 PM
Thanks... Thats a good point...
The mark I used on the flywheel was a white line actually it looked like two white lines... they where on the flywheel... Is that what I should have seen when looking into the housing from the top of the engine???
Old 05-21-2010, 08:56 PM
