tdc on exhaust stroke what would happen
What would I notice if I set the timing to tdc on the exhaust stroke
So I think That I put the belt on with tdc on the exhaust stroke. I think this because the engine rotates freely. nothing feels like it is hitting. However It will not start and when I shoot starting fluid in it ejects compression from the throttle body.
Does this seem like an issue with bad timing???
Again, Thanks alot
Old 05-21-2010, 11:59 PM
meister member
speedracing944's Avatar
The crank rotates 2 times for each revolution of the cam.
I am not sure what work you did on the car.
Did you line up the timing marks of the flywheel and the cam sprocket when installing the cam tower?
Did you verify and lock down the flywheel with both timing marks on the flywheel and cam tower synchronized?
Can you verify they are still synchronized?
If you answer NO to any of the tope 3 questions you may have bent valves.
1 more question. What method did you use to gauge the tension of the cam and balance shaft belt?
Please report back.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 05-22-2010, 05:03 AM
Proprietoristicly Refined
John_AZ's Avatar
I have been following his progress...
Timing belt quick question before starting
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-22-2010, 05:18 AM
good questions speedy
Here is what I thought I had done
before installing the cam tower I found and lined up a line on top of the bell housing
I then lined up the cam line and installed the cam tower.
When I went to install the timing belt a friend of mine pointed out that the line that I thought was the tdc line on top of the bell housing was not the tdc mark. we rotated the crank shaft several times and found an obvious white line in the top of the bell houseing. we then (with belt off) and cam tower on, rotated the came to line up its marks and put the belt on.
I at no point locked down the flywheel. but it was confirmed to be in the same place when finished.
If I where to start from scratch what would I do to time the engine. I am extremely confused, I have several lines on my flywheel that could constitute a tdc line
Old 05-22-2010, 06:38 AM
All Spooled Up
Try lining up the notch in the flywheel with the notch at the very BOTTOM of the bell housing. Are the camshaft & BS shaft markings now lined up?
Yes = The engine is correctly timed.
No = Rotate the crankshaft 1 full revolution & repeat the above procedure.
No = The engine is NOT correctly timed.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 05-22-2010, 07:02 AM
meister member
The problem with trying to synchronize the crank and cam with the cam tower on is you may bend valves if you have not already (depends on how far off you are). If the marks or not synched it would be best to pull the cam tower, synch the timing marks then reinstall the tower. If you now have bent valves you will have to pull the head in to have the damaged valves replaced.
Speedy
Old 05-22-2010, 07:22 AM
Is it possible that I may have put the distributor cap on wrong... I am doubting it, but is it possible???
Alright...
This time I am pulling my cam tower.
I will submit pics of each of the three openings to confirm that I have timed it properly.
Thanks guys...
It almost seems like I am making this harder than it is.
Old 05-22-2010, 07:39 AM
I have also heard that I can hold my finger over the first cylinder, and feel for compression. when
I feel compression I am on the correct stroke and just use a feeler tool to determine when the first cylinder is all the way up. then just line up the camshaft marks (way easy to read)
Old 05-22-2010, 07:45 AM
All Spooled Up
The caps are notched. Some of the last posts have pointed at the error the procedure that I outlined. You don't just go and turn the crank a full turn, when the belt is not connected to the camshaft. The procedure would ONLY be valid for a non-interference engine.
Old 05-22-2010, 09:16 AM
then with the head on and the cam shaft cover on... timing the engine can not be done???
Old 05-22-2010, 10:33 AM
Redline Racer
HondaDustR's Avatar
Well, to be safe, find 90 degrees from TDC on the crank, whichever direction is closest. Use a chopstick or a long screwdriver wrapped in duct tape through the #1 plug hole to find out. This puts all the pistons at mid stroke and out of the way. Turn the cam so the timing marks line up and then slowly roll the crank to TDC. Install the belt and double check the timing. Well, to be absolutely safe, you'd remove the cam tower, but that's a PITA and it can be re-timed without that if you do it right...I've done it before. With the belt correctly installed, you should feel a strong resistance every 90 degrees of camshaft rotation when cranking the motor by hand. If any of those are missing, at least one of your valves is probably toast.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 05-22-2010, 11:07 AM
winter-hater club member
nynor's Avatar
i think you can get the cap on 180 degrees out of time, or the wires could be wrong, or the rotor could be loose.
are you getting any backfiring when cranking the engine?
"COOL PRIUS!" - Nobody Ever
Old 05-22-2010, 11:14 AM
lol, heck yeah I am... Everytime I use starting fluid it puffs it back out at me... I just pulled the fuel rail and checked all the injectors... good there
I also checked a plug... definitely spark
I am pretty sure the plugs wires are on correctly. however can the rotor be backwards???
Old 05-22-2010, 03:34 PM
All Spooled Up
No, that is also notched.
Old 05-22-2010, 03:44 PM
well shoot...
So I must have set the flywheel wrong. To reset it in the right possition do I do it with the cam cover (valve cover) on or off. and with the timing belt on or off? I know I have asked before but I am looking for real clarity... I dont want to cause more problems than I have
Old 05-22-2010, 05:40 PM
nynor's Avatar
how much was it off? more than 10 degrees, you have bent valves.
to answer your question, i'd pull the cam tower.
Old 05-22-2010, 05:43 PM
Well that would suck... oh well at least I have another engine sitting next to it muhahah...
I am going to post pics later this evening with all of the marks in place. just to verify everything is not where it is supposed to be.
thanks for following this guys. I really appreciate it!
Old 05-23-2010, 08:07 AM
well all I have some news
The marks on the top hole of the bell housing where not the right ones...
I was about one 1/6th of a turn off. I had to rotate the crank just a smidgen to the right.
I am going to reset it Monday (fingers crossed)
Do you guys think that I bent valves? and how would I know if I bent valves???
Old 05-23-2010, 08:09 PM
nynor's Avatar
huh?
1/6th of a rotation?
1/6th of an inch, you are ok. 1/6th of a rotation, its gonna get expensive.
bolds are mine.
Old 05-23-2010, 08:14 PM
My Fault, I was unclear
I was almost 1 inch off
we barely had to turn the crank shaft to get it to line up
To reset it It is suggested that I find tdc,
Then make it go alittle further so that the pistons start to fall.
Set the cam tower
then rotate back to tdc so the pistons meat the valves?
What will I experience if the valves are bent
Old 05-24-2010, 06:45 AM
