-   -   trying to figure out what this is... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/546859-trying-figure-out-what.html)
N.A.S Story 06-07-2010 07:47 PM
Back for a little more help to ease my mind. realized this had like a vac line attached to it but was broken off. can anyone tell me what this thing is/ does and if its important.
<a href="http://www.flickr.com/photos/49475961@N08/4681051066/" title="what is this.jpg by thugginvdub, on Flickr"><img src="http://farm5.static.flickr.com/4019/4681051066_b6be905547_b.jpg" width="1024" height="608" alt="what is this.jpg" /></a>
nynor 06-07-2010 07:53 PM
vacuum canister. it stores vacuum, i believe, not sure exactly how necessary it is.
get a pen with the metal ink cartridge. cut the barrel off at the tip and about an inch below. epoxy the narrow end into the broken port. the vacuum line should reattach with a rubber boot. clean the ink out, of course, beforehand, with some rubbing alcohol.
Techno Duck 06-07-2010 08:06 PM
The tank is really only needed for when you use the HVAC controls.
nynor 06-07-2010 08:11 PM
that makes sense.
N.A.S Story 06-07-2010 08:15 PM
sounds good to me!!!
thanks for the quick replies. pictures make everything that much easier. back to the garage it go.
ernie9944 06-09-2010 02:20 PM
It does connect to the control valve (blue) coming out the brake booster follow the brown vac line.This is on an 83 your cannister is at a different location but do the same job.Techno Duck is rigth.
http://forums.pelicanparts.com/uploa...1276118027.jpghttp://forums.pelicanparts.com/suppo...s/beerchug.gif
running_cold924 06-09-2010 05:31 PM
ernie9944, what kind of oil filter is that? or is it a cap?
Cocacolakidd 06-09-2010 05:56 PM
Cap for Power Steering Reservoir.........the yellow one...???
ernie9944 06-09-2010 06:28 PM
This is a very very strong magnet sitting on top of the oil filter help keep all the microscopic debris out of your motor,had it for quiet a while it stick to the filter like glue & you got to really pull on it to remove it if you set it on a piece of steel forget it the darn thing act as if it's screw on there that how strong it is.:Dhttp://forums.pelicanparts.com/uploa...1276133144.jpg
running_cold924 06-09-2010 07:06 PM
OOOOOOOOHHHH........ok. I was thinking "where did he find an oil filter that looks like a star?"
that's pretty cool though, and it even matches your paint scheme
indio76 06-10-2010 12:07 PM
WOW!
Never seen such a clean under-hood!!
I wish I could have the same on mine!!
What kind of cables are installed for spark plugs? I would like to change mine tooSmileWavy
ernie9944 06-10-2010 01:03 PM
What kind of cables are installed for spark plugs? I would like to change mine tooSmileWavy[/QUOTE]
Thank's for the nice comment indio76 yes I use to keep the car very clean all around had it 26 years but sold it last summer ____the Grey spark plugs wires are Bosch Silicone (OE) 7mm, the yellow one from the Coil to the Distributor is an Accel 8mm wire that I fabricated myself .http://forums.pelicanparts.com/suppo...s/beerchug.gif
