Captain Carerra
whats left for it to possibly be
ok i just replaced my o2 sensor and a list of other maintenance items trying to sort out the hesitation issue i have with the car. the other items include: afm, air filter, fuel filter, plugs w/ wires, cap and rotor. haven't gotten the universal cat welded up yet but thats next along with the throttle switch that i didn't do yet. if i unplug the o2 it runs without the the hesitation but soon as i plug it up i get this spot at full throttle. now im thinking i might have to pick up a new dme computer and see if thats the problem. any other suggestions?
1987 944 build project (4.8L Iron Block LS...In Progress) 2007 VW Rabbit 2.5L 5cyl-Daily D 2008 VW Jetta 2.5L- date car...for now 2009 Kawasaki Ninja 250R-"The Gas Saver"
Proprietoristicly Refined
Just to review.
The AFM, you pryed the top off and put the guide on a new track? John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Captain Carerra
no i just bought a new rebuilt python unit off of here. the old one had already been slid on a new track once
What o2 sensor did you use. I did mine with a cheep after market once. And had the same problem.
OTR
(Mae) Red '86 944na- gettting new paint soon. (Abby) Black '86 944na- new addition to the family. |
Have you seen this thread? Rennlist thread: Hesitation under hard highway acceleration? - Rennlist Discussion Forums John
Captain Carerra
I decided to go back outside an look for the obvious vac leaks now since i do realize that the previous owner did build this engine and may have forgotten something...i knew i had one at the vac canister for the a/c controls. but i found the other right at the throttle body where it splits off in two directions and goes to the fpr...but this is what confuses me...if the fpr doesn't have a good vac i thought it would dump more fuel too as if it were disconnected. can someone tell me where this is suppose to connect to because i see no obvious extra lines in the area
Captain Carerra
i found a thread and it seems to be call a control valve (fuel related) where its suppose to be connected to....where is this located so i can hopefully find the line for it.
Captain Carerra
nevermind...so many names for it..its just the ISV...gonna look at it tomorrow and see it the line is disconnected. so close to running at correct temp i can feel it
