There is a hose on the bottom of my air box (86 NA) thats torn up and I don't know where it goes, what its called or what it does. Its about 7 inches long. I'm thinking its a breather hose for the emissions.
Any vendors sell replacements? Anyone have the diagram for the air intake? Cheers |
Pelican Parts Porsche Parts Diagrams and Locator
Links to the microfiche on pdf. Part numbers and all.
1983 944 - project mode 2002 Ford F150 - every other daily driver 1976 Honda Goldwing - the other days |
Found the diagram of the air box but can't find the hose on it. I will try to get a pic of it
What would Darth Vader do
Without a pic, I am only speculating.. But the hose may be the breather hose going from the bottom of the breather box to the top of the belt cover/housing. This was intended to give fresh air to the belts. However, there was a tech bulletin which eliminated the hose to make the belts last longer. Both sides of the openings were to be blocked off.
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
Going faster all the time
Heres the pic of the hose
![]() Last edited by RedDragon; 07-07-2010 at 05:15 PM.. |
Location: In a dumpster behind Albertson's in Los Angeles County
Looks like the hose that feeds cool air into the back of the alternator. Slide under the car, and see if there is a hose hooked up to the cover on the back of the alternator, if there isn't, that is most likely it, as I can't think of other hose like that under the hood of a 944NA. The breather hose is a rubber hose, not a paper/cloth hose. You can find the hose I am speaking of in the parts diagram, located at: MG 9 SG 02 Ill 902-00 (or easier look up, main group 9 electrical equipment, then scrool to "alternator with mounting equipment, it's part number 36 in the diagram (944.603.153.00)
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ![]() 1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi Last edited by 89-944NA; 07-07-2010 at 05:42 PM.. |
Red.. -That hose was actually attached to the air box? That is not the hose I was envisioning and it is not the one I was referring to. I think that 89-944NA (phil ) is correct.
Tags |
air box , hose |
