ERN911's Avatar
Turbo twist wheels
Can someone tell me if Turbo twist wheels 7.5x18 et50 and 10x1/8 et65 fit an 86 944Turbo
thanks
Ernie
1980sc/ Casablanca Beige
1987 944n/a White
1973E/Signal Yellow/ gone and Missed
1971T/Green/Gone
1988 944n/aWhite/Gone
Old 07-19-2010, 12:32 PM
racer's Avatar
Not without a lot of work. '86 year cars are "early" offset wheels.. Something in the 10-23mm ET.
The wheels you found are "late offset" or something in the 50-65 ET range. You would have to figure out how large an adaptor/spacer you would need to make it fit. Then you might have to , at least on the rear, worry about rideheight and alignment and maybe trim fender lips to make them work.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 07-19-2010, 01:10 PM
you need spacers the thickness of the difference between offsets, I had to do this my old forgelines.
86 951 well modded
94 968 Iris blue daily driver
Old 07-19-2010, 05:32 PM
