Help: Automatic Damper Plate to Manual Clutch
I have a 1987 924S that I've been restoring on and off for some time. The body/interior is nearly perfect. The motor was shot, but I have a 60k mile motor ready to go in it. I just installed new shocks, new control arms, new tie rods, sport springs infront, and turbo swaybars. Despite being an auto, it should be a fun little driver.
So when I pulled the motor I discovered it's about time for a new damper. I'd like to make sure I don't need to change the damper 10k miles after I install the new motor. I'd like to replace the rubber damper with a manual clutch. I have searched and found a number of posts about doing this, but nothing as far as a complete parts list. I have a compete manual clutch assembly including flywheel, clutch, pressure plate, bell housing, etc. Assume that I can simply install the manual flywheel, clutch, and pressure plate and call it a day. Am I missing anything? Any help would be appreciated. Thanks! -bj |
All Spooled Up
You are missing the pedal, master cylinder, slave cylinder, hydraulic hose, fork, and possibly some brackets.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
I mean I could convert it to a manual. I do have two extra manual transaxles, but then I'd need a manual torque tube, half shafts, peddle asemmble, etc. This is a DD, not a track car--I have enough of those. ![]() Thanks, -bj
1983 Porsche 944 Spec Race Car | 2002 BMW M Coupe Track Car 1983 BMW 635 CSI Euro LeMons/ChumpCar Race Car | 1987 BMW 325e LeMons/ChumpCar Race Car Clown Shoe Motorsports |
Go for it... let us know how it works out.
Good luck, George Beuselinck |
All Spooled Up
Oh, OK. My 1st P-car was a 77 924 automatic. Truthfully, I hate automatics, but I was unable to pass up on the opportunity. What I can say in favor of it, is that it was probably the most solid automatic transmission that I ever beat upon. I accidentally pushed the button on the shifter once as I was downshifting when starting to climb a mountain. As I struggled to quickly pull it out of 1st @72mph, I witnessed the tach wind all the way around past 9 or 10 grand. The only damage was a pie slice missing from the head of one of the exhaust valves. Must have floated it, I guess.
yes i am wanting to do the same, replace the damper with a manual flywheel and clutch plate, so any actual replies would be greatly appreciated.
86 guards red 944 NA |
Proprietoristicly Refined
Late model 944 manual clutch assembly into a late model automatic. In this case, the automatic transmission stays in. No parts list, this is OJT job. ![]() OR Here is a link on a full swap: Transmission fitment - Rennlist Discussion Forums Pedal and clutch master cylinder info (on a 928--close enough )Clutch Linkage GL John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Thanks!
I'm going to get going on this soon. I'll take some pics and document my findings. -bj
All Spooled Up
I don't know if it helps anyone or not, but the first time the plate failed on my 77 924, it was the splined part that the collar goes over that broke. I welded one from a (other make) used clutch disc onto it, and it held for a while. But when the rubber part later failed, so I ended up putting another one (from a JY) on it. I do remember that the shifts on that transmission were very hard - placing a great deal of stress on the rubber plate.
I have a good used dampner that I took out of a car that I converted to a 5-speed. Looks to not very old at all. Make me a offer.
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
All Spooled Up
Like Bill Engvall would say: There's your sign!
It is not that bad to convert to 5-sp. I have done 4 conversions. You already have most of the parts. It is a bolt in operation with no fab work required. The only thing you have to cut is the bracket that hold the auto shifter down. I always switch out the tt. Some folks don't and just drill the holes for the shifter. As far as installing a clutch and pressure plate instead of the dampner, you will greatly shorten the lift of the auto tranny. There is a reason Porsche put a rubber disc in there!!!
Oh... the dampner I have, I talked to the owner of the car I took it out of, it has around 10k miles on it.
Wanted to follow up. I ended up installing a manual flywheel, clutch, and pressure plate. There is a good chance that this car is about to be purchased and the new owner wants a manual transmission. So I installed the throwout bearing and clutch fork too. It should make the swap a lot simpler in the future. I have a write up and pics coming soon.
-bj
