-   -   Lazy question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/555244-lazy-question.html)
Gordon Rankin 07-25-2010 08:10 PM
Lazy question
Ok.. now for the lazy stupid question.. I need to test my drivers side window motor for viability. And I am too lazy to just pop the panel and do it before I ask..The two connections on the top of the motor are just + and - , right? I will be able to see if the motor works if I apply a 12 volt charge to the motor connections, right ?
AND, is the removal of the motor more than just removing 2 bolts or is it more complicated that this?
And yes, I've gone through the grounds, etc.
fmartenies 07-25-2010 08:27 PM
All the ones I have worked on are directional...so + and - are relative to the direction you want to go.
Gordon Rankin 07-26-2010 04:44 PM
Thanks . Please dont forget this question!
944 Ecology 07-26-2010 05:16 PM
more complicated than that.
