Porsche Crest Please Help...
I have a 84 944 equipped with the standard 2.5L SOHC. My problem is that the car fails to start when the key is turned. I have a sneaky feeling that it may be some type of neutral safety switch as the electrical system is intact. The battery has a charge but the only fluids in the motor is the oil. I am not sure if this problem has something to do with the tranny of motor? If anyone can help with suggestions I would greatly appreciate it. My 10 year old and I are working on the car as a first project...
Old 09-03-2010, 04:45 PM
Proprietoristicly Refined
John_AZ's Avatar
Hi old volks,
One of the common faults is the DME/FUEL PUMP relay. Do you have a spare?
If not make a jumper....
DME Relay Information and Testing
The next test is--------crank the engine and watch the tach, does the tach needle jump 1/16" a little bit? If not clean the connections to the reference sensors at the top back of the engine. Wiggle the wires.
Under the dash is the DME computer. Wiggle the big plug connector.
Here is a further troubleshooting list. Read all of Clarks as well:
Troubleshooting - Engine
I hope you have coolant in the engine to go along with the oil......
GL & welcome
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-03-2010, 05:02 PM
Thanks for the replies, I will go down the list, and I WILL add coolant...
Old 09-03-2010, 05:07 PM
Born2bwild1191's Avatar
...so there was no coolant prior to him telling you?
'87 Guards Red 924S - First Porsche - SOLD 5/21/10
'67 Red VW Beetle - Restored by me and my dad, 2115cc motor.
'87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE
'92 Ford F150 - Winter truck
'04 Yamaha R6
Old 09-04-2010, 09:29 AM
Custom User Title
mikepellegrini's Avatar
Has this car been sitting for a long, long time without running?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 09-04-2010, 06:55 PM
Simple
You may have already checked this but I had starting problems because of the wires that connect to the battery terminals. They were a bit old looking but nothing too big deal But no matter how well I connected them, the car would either do absolutely nothing when the key was turned, or acted like the battery was weak and would almost turn over. I had the battery checked outside of the car and it had a good charge. I ended up completely replacing the ground wire and then cut back the red wire and made sure to get good fitting connectors and crimped them on well. Everything worked well after that and its been going ever since.
Old 09-04-2010, 07:04 PM
winter-hater club member
nynor's Avatar
is this an automatic?
"COOL PRIUS!" - Nobody Ever
Old 09-04-2010, 07:31 PM
