-   -   Wondering how to do this? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/557232-wondering-how-do.html)
Mr.Acura-te 08-05-2010 02:43 PM
Hi all later tonight I will post a little more about myself.
I am restoring a '84 944 and I am having a little trouble figuring out how to remove the Porsche Crest from the nose panel. I have been searching for a good solution most of today but I haven't seemed to have had any luck.
I have been using the Tech Info on this website with some of the things on the car so far and would just like to let you all know how wonderful that has been in helping me with different things.
Thanks,
Ron
mistertate 08-05-2010 03:39 PM
stick your fingernails under it and pull it off
stogie25 08-05-2010 03:42 PM
Clark's Garage has a write up for that.
http://www.clarks-garage.com/pdf-manual/body-13.pdf
Slam 08-05-2010 04:16 PM
Failing Clark's, just ask any teenager - they steal these at an alarming rate.
Mr.Acura-te 08-05-2010 04:21 PM
Thank you sir, can't believe I missed that. Really was hoping not to have to take off the nose panel. I really feel like it wouldnt be too bad of an idea to just pry it out and re attach it with some 3M tape.
Mr.Acura-te 08-05-2010 05:47 PM
Sorry to double post but. It was relatively easy to remove the crest.
http://sphotos.ak.fbcdn.net/hphotos-..._4474959_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-..._1651154_n.jpg
Good thing my other 944 parts car has a crest that is in way better shape.
gmorken 08-05-2010 07:33 PM
Thanks,
Ron
I found by removing the front bumper (2 bolts), there was plenty of room for my hand to go behind the nose panel and remove the nuts holding the crest on. Much easier than trying to remove the nose panel... added benefit is I got to detail the bumper components on the workbench (still early in our restoration so removal worked out perfect)... .
Mr.Acura-te 08-05-2010 07:52 PM
Did you miss my previous post? All you need is a painters multi-tool aka 5-Way and you can just pop that sucker right out of there.
cauzomb 08-05-2010 10:11 PM
Yup, they are easy to get off.. but installing the new one? do the blind nuts stay in place? The early header panel is spot welded, not removable.. There is a small through hole in the internal air channeling "sheetmetal" below the header panel, they somehow fit a tool in there for installing the porsche crest, it's a very tight fit. I don't think you can get at it if the stock radiator plastic ductwork is in place. After looking through a few other posts on the subject, it looks like there are just plastic inserts in the header panel that captivate the badge by friction... no need for tools.
Mr.Acura-te 08-05-2010 10:55 PM
Yeah and if you would want added safety just put some 3M double stick on the back of it and it isn't going anywhere.
89-944NA 08-05-2010 11:53 PM
When you reinstall the badge, use a blow dryer to CAREFULLY heat the rubber gasket, then put the gasket on the badge. It's a bit tricky, but if you heat the gasket, it will lay correctly when installed (no edges rolled under).
Mr.Acura-te 08-06-2010 12:00 AM
Thanks for the tip sir. Could someone point me into the right direction to post up pictures of my restoration?
cauzomb 08-06-2010 01:35 AM
When you click on the button "post reply" or "go advanced" next to the quick reply box, there should be an option to attach an image or two.
Originally Posted by pelican advanced reply
Attach a Photo
You may attach a photo of nearly any size - we will resize it for you.
Click here to Upload a Photo... (Valid file extensions: .gif .jpg)
Best to keep the pixel dimentions 800x600/150KB in size or less, larger files get processed "smaller" and sometimes loose quality.
