-   -   Rollers/Sprockets/Pullys Torque Specs? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/561654-rollers-sprockets-pullys-torque-specs.html)
OK-944 08-30-2010 08:58 AM
I've installed the various front pullies/sprockets on my 85.5's engine, and know that the torque setting for the main crank is 155 lbs. and balance shaft sprockets are 33 lbs.
Doing various searches, I've come up with 33 lbs. for both timing belt and balance shaft tensioners.
My assumption is that the timing and balance idler pulllies, due to the same bolt size, should also be set at 33 lbs.
Sorry if this seems like a no-brainer...but I cannot find reference to the above torque specs and want to do this right. Thanks!
Lawrence Coppari 08-30-2010 09:08 AM
That's what I've been using since 1996 on mine.
dryslick13 08-30-2010 10:33 AM
That is the correct torque settings based on Hayens Manual.
looneybin 08-30-2010 10:50 AM
that's also the correct torque per clarks garage
mst758 08-30-2010 11:26 AM
Does Haynes make a manual for 944S's? I have ordered one from local parts store twice and they only send the one for SOHC.
looneybin 08-30-2010 11:48 AM
i think i've seen a Haynes manual for the S2, but i'm not 100% sure
