Zombie
Rollers/Sprockets/Pullys Torque Specs?
I've installed the various front pullies/sprockets on my 85.5's engine, and know that the torque setting for the main crank is 155 lbs. and balance shaft sprockets are 33 lbs.
Doing various searches, I've come up with 33 lbs. for both timing belt and balance shaft tensioners.
My assumption is that the timing and balance idler pulllies, due to the same bolt size, should also be set at 33 lbs.
Sorry if this seems like a no-brainer...but I cannot find reference to the above torque specs and want to do this right. Thanks!
Old 08-30-2010, 08:58 AM
That's what I've been using since 1996 on mine.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-30-2010, 09:08 AM
That is the correct torque settings based on Hayens Manual.
Old 08-30-2010, 10:33 AM
unindicted co-conspirator
looneybin's Avatar
that's also the correct torque per clarks garage
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 08-30-2010, 10:50 AM
Does Haynes make a manual for 944S's? I have ordered one from local parts store twice and they only send the one for SOHC.
Old 08-30-2010, 11:26 AM
looneybin's Avatar
i think i've seen a Haynes manual for the S2, but i'm not 100% sure
Old 08-30-2010, 11:48 AM
