Porsche Addicted
bnv944's Avatar
Exclamation Help help help!!!
so at noon today i have emissions. i have no cat and a custom exhaust. they passed me before with a cat on that i later found out (when i took it off) that the honey-combs inside were in pieces. i need any cheats for passing without a cat ASAP plz.
*1987 944 n/a. project car.
*1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert
*2001 Jeep wrangler SE - THUMPER
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 09-09-2010, 07:44 AM
unindicted co-conspirator
looneybin's Avatar
if you have a visual inspection then you're toast
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 09-09-2010, 08:05 AM
Porsche Addicted
bnv944's Avatar
i know
Old 09-09-2010, 08:07 AM
Porch's Avatar
Since a visual inspection is part of the process, you're toast.
You could have a cat installed, that would fix your problem!
~Chris
1990 Porsche 944 S2 - LS1 / AOR / 968 M030 Sways / 300# frt 28mm rear
1993 Jeep Cherokee - 3" Lift, 30" tires
Old 09-09-2010, 10:55 AM
Redline Racer
HondaDustR's Avatar
Dump the pieces out of the old cat and put it back on. It'll pass visual since it looks like a cat. There's no way they will take it apart and look inside. It's possible you could pass if your car is running really well.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 09-09-2010, 11:29 AM
