Toran's Avatar
Fuel Leak near rear passenger wheel
Hello Good People!
Can someone please help identify this leaking part.
Ya its an old hardline but can't seem to get the car up high enough to follow it farther back.
T.I.A.
86 944na Alive and Rollin
Old 09-13-2010, 12:38 PM
CorsePerVita's Avatar
if it's the one i'm thinking of it's one of the main lines, should pass into a fuel filter up in that crevasse somewhere. dear god that looks nasty. have those lines been replaced ever? cheap insurance for a car not to go up in flames.
1970 Porsche 914 1.7L, 1982 Porsche 911 SC Targa, 1977 Porsche 924, 1979 Porsche 924, 1999 Ducati 900SS
Old 09-13-2010, 02:27 PM
Toran's Avatar
Original lines. Kinda out of site and out of mind till something like this happens.
Having issues finding a part number. Any clue?
Old 09-13-2010, 02:54 PM
ernie9944's Avatar
Could be #17 or #22, but seem to be 22 witch run on top ,could you take a better pic .You got no choice you'll have to get it up & check can't drive it like that.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 09-13-2010, 03:55 PM
Toran's Avatar
Thanks for the visual!
I'll take a better picture in the morning.
Will replace 17, 18, 19, 21, 22, 23.
Are these specific dealer parts or can they be replaced with other metal lines?
Pelican parts?
Old 09-13-2010, 04:51 PM
Toran's Avatar
Found the leak!
Is there a newer and improved method to repairing/replacing these lines, material, fittings etc?
Are there any temp fixes that can be had at a local store?
Old 09-14-2010, 08:41 AM
Custom User Title
mikepellegrini's Avatar
Yeah, there are some good temporary fixes, but none I would use. I've had cars burn up a couple times and gasoline scares me bigtime.
You've got to ask yourself one question: Do I feel lucky? Well, do ya, punk? (Apologies to Harry Callahan).
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 09-14-2010, 07:23 PM
Toran's Avatar
Even Dirty Harry would need a temp fix every now and again.
So you hardcore Porsche fans have simply replaced these fuel lines with OEM parts?
Old 09-14-2010, 10:41 PM
968 GUY's Avatar
Replacing with OEM hardline would be the best soloution, but if you look at the diagram, you can see that some flexible lines and hose clamps were used. The auto parts stores do have hoses rated for fuel, and at a higher pressure. That looks like the supply side, so a fuel hose rated at a higher pressure than the fuel pump might be a good substitute, use good quality clamps that do not cut into the hose.
Ken
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 09-15-2010, 11:58 AM
Toran's Avatar
Just to get a better understanding of the options/objective would one be looking for 8mm and 10mm steel hard line?
What size/type fitting?
Old 09-17-2010, 12:23 AM
Toran's Avatar
Good news... the hard lines have arrived!
Is there a technique for getting the car high enough on jack stands to install these lines?
Old 09-24-2010, 04:25 PM
Go incrementally one side at a time (F/R or Side to Side) and realize the rear suspension carrier weighs a bunch and will significantly alter the balance once lowered for install clearance, depending on what's in the fuel tank for ballast.
Old 09-24-2010, 09:12 PM
