Heater control problem
My '86 Turbo went to full heat the other day. $4 later I have a new heater clip and no heat :confused: With the ignition on, turning the temp control doesn't result in any movement on the blend motor. All other functions on the climate control work - fan control and foot and defrost controls. Where do I start to trouble shoot this?
You might want to check out clark's garage.com at the link below.
944 HVAC Operation and Malfunctions Cheers, Larry |
Yes, I'd seen that before and it's a helpful general guide, buy doesn't cover my specific problem. Anyone else had this issue before?
Pigeon, I had the same problem with mine. checked everything Icould think of, ended up being the heater control unit and theres no way to test it according to clark's garage because its electronic. just found agood used one on this site took the chance and it worked
Thanks for the reply.
Problem fixed - it was a bad fuse. The fuse wasn't blown but the contacts were dirty and somewhat corroded. A new fuse solved the problem.
| All times are GMT -8. The time now is 02:30 PM. |
