944 Stuck in gear?
I recently bought a 1986 944 Turbo that has been sitting in a friends driveway for the past 6 years, I had a flatbed wrecker pick it up. We checked to make sure it was in neutral and hooked up the cable and pulled it on the wrecker, it rolled fine.
Got it home and it rolled right off of the wrecker and into my workshop, no problems.
The parking brake handle is stuck (a future post I am sure) so I put it in gear so it wouldn't roll around. It needed some body work so it sat for a few weeks while I worked on it. A few days ago I was going to move it out of the shop to clean the shop for painting, it wouldn't budge! I checked to make sure it was in neutral and the shifter acted like it was, I could feel the linkage moving, I ran it through the gears (5 speed in case I forgot to mention it) and again put it in neutral, still wouldn't budge! I put it up on jack stands and crawled under to make sure the linkage was actually moving, it is. Just to make sure I reached my hand up to the linkage at the transmission and moved it from under the car, I could feel it go forward, backwards rock side to side (must have been neutral) still nothing! It is not the brakes stuck, the CV's move ever so much as I rock the wheel. It couldn't be the clutch stuck could it? Seems like if the transmission is in neutral the car should move?
Anyone else have this problem, or know what it could be?
Rusty
Old 09-19-2010, 02:15 PM
Arizona_928's Avatar
Try pressing the clutch in and see if she will roll.
dolor et pavor
Copyright
Old 09-19-2010, 09:21 PM
Porsche Addicted
bnv944's Avatar
theres two linkages on the shifter, one to move it side ways (a bolt by the transmission) and one to move it back and fourth (a clip under the shift leaver) the clip could have popped off and the pin would slide out when u move it side to side. check the pin by removing the boot.
also if the parking brake handle is stuck UP, then the e-brake would be on, hopefully. if i can think of anything else ill post back.
good luck =)
*1987 944 n/a. project car.
*1989 mazda B2200 beater <-- Update: sent away to be made into IPODS. RIP huebert
*2001 Jeep wrangler SE - THUMPER
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 09-20-2010, 05:19 AM
ernie9944's Avatar
good luck =)
#16 is the clip
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 09-20-2010, 06:56 AM
fastfredracing's Avatar
I cant help to wonder if the parking brake mechanism/or cables are rusted and once you put it on , it is stuck, preventing the wheels from turning. I have never seen a 944 get jammed in gear, 911 is a whole other story.
No left turn un stoned
Old 09-20-2010, 09:15 AM
The parking break is stuck down, off, so it is not the problem.
I will check the linkages again, it is still up on jack stands so will crawl under it and see what I can find.
The pictures and schematics will help to see what I am looking for.
Rusty
Old 09-20-2010, 10:58 AM
In the photo, I assume the shaft coming from the shift lever goes onto the part labeled "A"? And it is held in place by the bolt labeled 19 in the schematic?
In the photo what do B, C & D do?
If I can understand how it works it will be easier to find the problem.
Rusty
Old 09-20-2010, 02:54 PM
James Chimney
check bolt #25, mine was lose and shifts where real bad.
Old 09-20-2010, 03:39 PM
ernie9944's Avatar
Originally Posted by Rtarh2o View Post
In the photo, I assume the shaft coming from the shift lever goes onto the part labeled "A"? And it is held in place by the bolt labeled 19 in the schematic?------ YOUR'E rigth Rusty
Rusty
Those bolts (A B C & D) should be check once in a while to make sure none are loose,specially bolt #19 that goes in A ,I beleive it has a hole in it & a lock, if you do remove it make sure you lock it back.Originally this pic was sent with another one as reference for installing a Schneel short shifter kit hence the A B C & D letters.While at it check the plastic bushing #10 holding the ball at the end of your shifter,this little fellow can also make your shifter quiet sloppy. Good luck finding the problem
#10
Old 09-20-2010, 05:17 PM
