heavy rain, then I discover fan on?
The other night we had a heavy rain/t-storm. In the AM I went out to get into my winter beater, and my 944S had 1 fan running. (passenger side)
No idea how long it was going. I pulled the relay and went to work. WTF?
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
Holy moly!! How was the battery? Looks like it's trouble shooting time Rick.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Thermo-fan switch? The P.O. of my car had the engine rebuilt because of this and a wrong diagnosis.
Its trouble shooting time for 2 reasons, Jr. 1) AFAIK, on late cars both fans run on slow for a few minutes after shutting off the car, only one was running. Could be a fuse problem cause both should run at the same time. Only early cars have 1 fan running at shut off. 2) It could be the thermal fan switch OR the cooling fan relay. It depends. The way to check for this is to disconnect the thermal fan switch. If the fans continue to run, it's the cooling fan relay. If they stop, it's the thermal fan switch.
Toofah King Bad
My S did this. . .bad relay.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Thermofan switch is new. hmm...relay? Will have to do the tests I suppose.
Its pretty much time to stow her away, so I'll have a look at it on the weekend. Can the relay come apart for cleaning?
All Spooled Up
Yes, I've done it many times. Bend the tabs out far enough to clear the board, and the plastic housings on the relays will slide right off. AKAIK, my fans DO NOT come on when the car is turned off. The only exception to that is if they were already on when the car was turned off.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Isn't it just a board with 2 standard relays attached under that metal cover?
All Spooled Up
Oh, it's a metal one? I've never actually had one of those apart, but I believe that it still should not be a problem.
If you were from sin city, I would have thought that you were somebody else!
Well, I opened the relay. There's 4 coils within, each has its own "points" doodad when energized. None were stuck closed.
However, there's corrosion on several of the larger solders on the backside of the board....hmmm...should I clean and re-solder? OR...is there a VW / Audi / Volvo relay that will work? (and is cheaper than Porsche)
response in blue.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
I think it was in high speed running, but the battery was weakened. (probably running all night!)
It did it once before (dry day) and I tapped the relay and it shut off. I've searched...the corrosion is likely the solder breaking down/crystallizing. hmmm...scrape up, resolder is what I'll try. None of the coils looked like they were stuck, as I pushed them to connect/disconnect and they sprung back normally. Do you really need 2 coils for each speed? I was wondering if you could simply replace with 2 new separate relays instead. Maybe I'm wishful thinking.
Response in blue
Well, I'll grab the FIL's solder gun and reheat/add a drop or two to each spot that looks crystallized and see what happens.
I'm still looking for a cheaper alternative to the pricey P-car relay. My "cheapness" sense is tingling...gotta be one!
here's a pic....
Am I screwed?
