Guest1287's Avatar
This can't be right
I'm trying to change out the broken gear in the odometer and I got the gauge out of the cluster. Now I'm told from Clarks garage that I have to "Remove the bezel from the front of the speedometer by prying up on the bezel's back lip with a small flat tip screwdriver. Work around the circumference of the lip until the bezel is free from the unit. "
So basically have to destroy the the bezel to get it out of the housing unit. Once it is bent out of shape it seems it with not be able hold it in place ever again.
So WTF*%K!
Old 10-12-2010, 09:38 AM
Back from Beyond
Yes and no. You will deform it, but you should be able to bend it back over the mounting flange when you're done by working your way around it. The downside is it'll never look stock.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 10-12-2010, 09:48 AM
Guest1287's Avatar
WOW, that just seems like some really bad design flaw. So if I brought it to a mechanic, he would do the same?
Old 10-12-2010, 09:53 AM
Back from Beyond
Pretty much. The black metal ring is put on originally by a machine kinda like a can opener that seals cans instead of opening them, if you get my drift. I don't know if I'd call it a flaw, considering anyone buying a car can pop out the gauge and see right away if it's been messed with.
All others GONE!
Old 10-12-2010, 09:56 AM
unindicted co-conspirator
looneybin's Avatar
i think they mean the "needle" not the bezel.
You have to pry the needle off to be able to unscrew the bezel, then it just lifts off to expose the gauge internals
OH - MY BAD i just noticed it's an early dash - ignore me - sorry
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 10-12-2010, 09:57 AM
Guest1287's Avatar
"I don't know if I'd call it a flaw, considering anyone buying a car can pop out the gauge and see right away if it's been messed with."
That is an excellent point. I finally got it off with minimum damage. It actually didn't need a new gear, it just needed to be aligned with other gear below it.
It was almost impossible to get the speedometer cable attached to the gauge. But the odometer works again and the cluster looks just like it did before.
Old 10-12-2010, 02:58 PM
umm...did u seal it up yet? are u talking about the final odometer gear to worm gear align? cause if it popped out of alignment once, it'll pop out again. u might need to notch the gear or something on its spindle so it does't move.
mine popped out again this season. i'm still procrastinating opening that up again
Old 10-12-2010, 03:13 PM
early 944's very rarely break the gear like the later cars...but this problem will happen again if you dont use a dab of crazy glue to hold it in place
Old 10-12-2010, 06:56 PM
ernie9944's Avatar
I did a flat faces mod two years ago on my 83- 944 ,you got to be an angel from heaven to take then bezels out without destroying them,took me two days to complete the job lol never never will I do it again.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 10-12-2010, 07:23 PM
