Sensor/Flywheel Gap - Auto Positioning Bracket?
I forgot to gap the speed sensor prior to installing the bell housing...so used the "business card" method of building up a .8mm thickness on the bottom of the sensor, stuck there with two-sided tape.
This turned out to be totally unnecessary. My speed/reference sensor bracket has a metal tab which lowers against a stop when installed - positioning the sensors perfectly. I know this because I actually built the "business card" shim up to just over 1mm, and with this extra amount there appeared a very slight (almost invisible) gap between the metal tab and the stop.
I think I have the "old style" sensor block...as it features the third hole for the TDC sensor, which nowadays, I take it, is no longer used.
Anybody else have a sensor bracket that positions itself?
Old 10-01-2010, 05:15 AM
Proprietoristicly Refined
John_AZ's Avatar
Old and New style of sensor brackets have an adjusting slot---shown by tip of pen. Opposite the adjusting slot is the "pivot sleeve". The pivot sleeve moves the adjusting slot UP & DOWN to position the reference sensor .8mm (less than 1mm) above the FW(flywheel)
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-01-2010, 08:22 AM
