APE Maf potentiometer broke.
Can I just go to radio shack and buy one that tunes to 2.2k ohm? The one they supply isn't anything special right? Might be a dumb question. Also, it has to be 2.2k acorss the connector leads, anyone know how much added resistance is is the unit and the wiring so I know what ohm range i need?
And on the AFM, the air temp sensor resistance is read on the last two plug terminals. Therefore, the APE potentiostat, basically acts as the air temp sensor i think, should also read on the last two terminals right?
Old 10-08-2010, 10:15 PM
CPR CPR is offline
The Splitter Maker
CPR's Avatar
Yep.
PATRICK
Built fast to last with:
CPRacing~Vitesse~PowerHaus~FabSpeed~TiAL~NiTTo
Old 10-09-2010, 06:53 AM
All Spooled Up
Another, more simple option, would be to simply replace the pot with a 2.2K fixed resistor.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-09-2010, 09:31 AM
