overkill's Avatar
Send a message via AIM to overkill
I'm not scared to spend money! I am going to join PCA and I definatly want some...
sorta turbo/super charger added! I dont think I can handle just an engine! So far I found out that if I add a turbo/super charger with 944S compression ratio the engine will so called blow up...right? Also, i found out that the head needs to be heat treated...right? I can lower the compression ratio, but that will cut down on my HP, but if i cut down just a little to keep engine from blowing up. The HP that is lost from the lower compression will be made up from the super charger. With upgraded intake/ intercooler/ fuel pump/ head/ ignition system/ chip/ exhuast...basically the whole nine yards, would it be safe for the car?
{1987}944S - (SOLD).
Old 01-15-2002, 03:31 PM
Roger Hall's Avatar
Why
Why bolt on performance and then tear down the motor.
GO BIG OR GO HOME!
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 01-15-2002, 05:08 PM
RaF944's Avatar
wow do you incorporate a turbo/supercharger question in all of your posts?
1993 Porsche 968
85.5 Porsche 944
Old 01-15-2002, 07:23 PM
