What J size wheels fit narrow body?
Hi im doing a 5 stud conversion to a 924 n/a
require 5 stud wheels, but not sure which 5 stud alloys will fit within the narrow body ? Last edited by the black 924; 10-17-2010 at 05:59 AM.. |
Toofah King Bad
8", late offset wheels fit under my 931 rears, after I rolled the fender lip. I used 6" up front, and with the stock springs, I could barely get my finger between the tire (205/50) and the spring.
Gratuitous pic:
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
The standard 924 4 lug n/a wheels are 6J
so i guess 6J front and 7J rear would be most comfortable? widest option - without body work modification whats the late offset |
Toofah King Bad
Actually I think the best setup would be 7s front and rear (a thin spacer can be used up front to get the tire off the spring).
The "late offset" 911 wheels are around 50 ET.
interesting
so a 7J wheel with a spacer would still fit within the body? id like to use 944 cookie cutters. They all seem to be 7j with 944 offset |
Toofah King Bad
Cookies are "early offset." Call Wheelenhancement.com for more ideas and advice.
Confirm this fits. I run Cup 93 993 16x7 ET55 wheels all round, 225/50 rear, 205/55 front. Front needs a 7mm spacer (I have KW v3 coil overs, so spring clearance is not a problem, but rub on full lock inside wheelwell is). Rear has 5mm spacer just to widen the track a bit.
924S 1988 KW3 v3, Wilwood brakes, and a diet. Oh and a 3L 16V drivetrain |
Offset is the difference between the wheels centerline and the mounting surface
"early" offset refers to an offset in the 10-23mm range. These would include cookie cutters, fuchs and some phone dials. "Late" offset refers to the 40-65mm range. These would include some phone dials, D90s, Clubsports, Dish/trashlids style wheels (928 wheels). An early offset won't fit because it pushes too much of the rim to the "outside" of the fender. 924s run "late offset" wheels to get thier width towards the inside of the fender well, hence the concern of rubbing a strut/spring.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Thanks you guys I learnt something new about offset. Its never meant much to me. i just go blind. saved me wasing money on the wrong parts.
are cookie cutters made with the late offsett? i really want cookie cutters for the black and polished rim. |
nope, cookie cutters were early only
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
![]() Really well thats crossed out how about the unaffordable fuch wheels |
fuchs are early offset only (iirc) but because they are a sort after rim, you can buy copys made in late offset. what exactly do you have on your 924? i know you were going to 5 stud but from which year? 944's changed to late offset in 87
Thanks thats good information. Cars a 1984 n/a 924 4x108
I currently have audi 80 4x108 15" rims with 20mm spacers
You can put 7X15 cookies in the back (you'll need to pull the 21mm spacer and go with shorter studs, but they wll fill the wheel wells up nicely) and then put 6X15 cookies upfront (bolt right up and look great). Or just put 6X15 cookies all the way around.
Currently Without Porsche 1981 931GT (SOLD) 1985 911 Carrera Targa (SOLD) |
