Skidpad rating
I read that stock 88 turbos pull like .90 G's on the skid pad in 88, does anybody know what it is with modern tires? Has anyone tested this? Also, what kind of G's do 944 race cars pull with slicks and lots of suspension stuff? I know it depends on other stuff, but I'm sure someone has a range. Just curious, thanks guys!
'87 Guards Red 924S - First Porsche - SOLD 5/21/10 '67 Red VW Beetle - Restored by me and my dad, 2115cc motor. ![]() '87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE '92 Ford F150 - Winter truck '04 Yamaha R6 |
"THERE IS NO SUBSTITUTE"
i know one 944 that can pull bout 1.4 g in corners
All Spooled Up
Is this a reference to the recently adveritzed 1G street tires?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
I bought an app for my iPhone that appeared to work pretty well until i took it to a parking lot and it told me I pulled .99. I stopped using that app after that.
it isn't all that had to pull over 1G, if you are willing to set the car up for it - just tires though won't get you there, though it will get you a couple of tenths over stock
Holy cow that would be fun. Wild man, not a reference to that commercial, although I do know which one you're referring to. This actually came about because a friend of mine bought a GT500 and was looking up specs, and I wanted to compare my car to it, which led to more questions
Don't forget to compensate for body lean - at least if you're anywhere near stock spring rates.
Once you get up to 30mm torsion bars, that problem goes away. (my racecar's running 34's - if I can't hit 1.2g, I'm not trying)If you have the Gen 2 Goodyear Supercar tires on your '44, you'd have no problem beating the Rustang on the skidpad. Great tires - well, once it's above 70 degrees and you get some heat in 'em! LOL
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
Coming up on your left...
At least your car doesn't have a truck's rear end
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire
All Spooled Up
Do the the 951S stock TB's go 30? Anyways, is THAT the make/model of tire that boasts 1G+ in the commercial? I can't remember. Gotta go now. I want to get my exhaust on before the rains start today.
LOL, no the 30's would be strictly the aftermarket ones.
Truck rear end FTL is sure right! We race against the older 4-cyl Rustangs in ITB (with our 924's)... they handle OK in a straight line, but have a tough time putting the power down as well as the 924/944 rear end... and the front end is absolute crap, even worse than the rear... We spot them 300cc's in motor, 100 or more lbs, and they still are well behind. The hot exhaust setup for them apparently is the exhaust manifold from a Ford Ranger pickup.
Vaughan Scott http://www.vaughanscott.com http://www.924.org Last edited by 924RACR; 11-30-2010 at 06:31 AM.. |
Yeah, already ripped on him about the truck-car he drives
I personally don't like them very much. Didn't know about the exhaust, that's funny. I think the tires in the commercial were Bridgestones if I'm not mistaken...
your average wrencher...
lo, "it's not the tires screaming, IT'S the asphalt!"
the bridgestone commercial from a couple months ago....
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
The 1g tire is BFGoodrich. But there's more to a tire than absolute grip. What about wet grip? Wear pattern? Steering feel? Cost?
BFG's are good tires but I think there's better ones out there. The Dunlop Direzza Z1 Star Spec (or whatever) are AWESOME and they're not obscenely expensive.
All Spooled Up
I always thought dunlop was a pretty good name. Can't say the same for the the BF name. But I do think that claimin' a G is the makin's of some pretty damn awesome advertizin'.
