GreenWater's Avatar
Continuity of distributor rotor???
Still trying to resolve a no spark issue. I have a new distributor cap and rotor. It seems that power is going into the distributor cap but not leaving it.(I think) I am trying to take readings of every wire and everything I possible can. I took a continuity reading between the two ends of the distributor rotor and got a strange reading.(new rotor) I already threw away my old rotor so I can't take a reading of that one to compare. Continuity between the center of the rotor and the end of the rotor gave me a reading of about 1100. I would have to assume that it should give a reading of 0. Can someone please help me out and see what kind of continuity reading they get on their distributor rotor? It would help so much.
-Thanks
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 10-28-2010, 02:32 PM
All Spooled Up
It past quitting time now (my self-declared quitting time, anyways) on the east coast, but if nobody respond by tomorrow, I check both mine 4 U.
I WOULD NOT however, assume that something made of carbon should read 0 ohms.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-28-2010, 03:44 PM
GreenWater's Avatar
Thanks wild man.
Carbon? Mine is brass. Black plastic with brass in the middle. That is why I am assuming a reading of 0. I was also checking continuity not resistance. Thanks.
84 944
Old 10-28-2010, 04:12 PM
All Spooled Up
Oops, my bad, it is the cap that has carbon in the center.
All right, I'll go out and check (only 1) of mine. B rite bak...
These are the readings I got:
rotor - 1122 ohms
cap - 1090 ohms
wires - approximately 3K/ft
There you go. There is what looks like an epoxy-covered trough between the center and outer contacts on the rotor. There's probably a slab of carbon under the epoxy.
Old 10-28-2010, 04:33 PM
GreenWater's Avatar
Thanks so much.
84 944
Old 10-28-2010, 06:42 PM
All Spooled Up
No problem.
Old 10-29-2010, 12:26 AM
