NEED help !!!!!
went to take fron cover off to examine the balance shaft and timing belts, thought they were to tight because the really loud wine, there were perfect. put back to gather does not run right idles very rough and seems to cutting out, what happened please help!!!!!
Did you mess with the tensioner(s)?
did u actually remove the belt?
You must have upset the wires around the distributor. Did you disconnect the ignition leads to check the belts? If yes - did you put them back in the right order and/or push them on all the way. Otherwise check all the smaller wires are properly connected around that area (e.g. Hall sender)
no i did not mess with tensionor, remove belt, or take wire off distributor
wow im dumb u guys made me remeber i took off my second spark plug to get to vacumm clamps i was fixing them, wow thats what i call working on cars to long
no i know how it feels like to be a smart car (3 cy) did not feel good jk
...is it still whining?
When were the waterpump or pulleys serviced last? |
it was in old thread, got sevecied 11 years ago long story, but its getting done new belts along with pulleys and water pump. i guess it doesnt even have the upgrades water pump the difference i dont know?
http://forums.pelicanparts.com/uploa...1288476554.jpg http://forums.pelicanparts.com/uploa...1288476587.jpg Upgraded Water Pump Kit.:D |
| All times are GMT -8. The time now is 04:00 PM. |
