"THERE IS NO SUBSTITUTE"
mayPOR944's Avatar
NEED help !!!!!
went to take fron cover off to examine the balance shaft and timing belts, thought they were to tight because the really loud wine, there were perfect. put back to gather does not run right idles very rough and seems to cutting out, what happened please help!!!!!
Old 10-29-2010, 10:18 AM
All Spooled Up
Did you mess with the tensioner(s)?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-29-2010, 11:32 AM
did u actually remove the belt?
Old 10-29-2010, 11:41 AM
You must have upset the wires around the distributor. Did you disconnect the ignition leads to check the belts? If yes - did you put them back in the right order and/or push them on all the way. Otherwise check all the smaller wires are properly connected around that area (e.g. Hall sender)
Old 10-29-2010, 11:50 AM
mayPOR944's Avatar
no i did not mess with tensionor, remove belt, or take wire off distributor
Old 10-29-2010, 12:22 PM
mayPOR944's Avatar
wow im dumb u guys made me remeber i took off my second spark plug to get to vacumm clamps i was fixing them, wow thats what i call working on cars to long
Old 10-29-2010, 12:57 PM
mayPOR944's Avatar
no i know how it feels like to be a smart car (3 cy) did not feel good jk
Old 10-29-2010, 01:06 PM
rickharrison's Avatar
...is it still whining?
When were the waterpump or pulleys serviced last?
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 10-30-2010, 06:55 AM
mayPOR944's Avatar
it was in old thread, got sevecied 11 years ago long story, but its getting done new belts along with pulleys and water pump. i guess it doesnt even have the upgrades water pump the difference i dont know?
Old 10-30-2010, 08:45 AM
ernie9944's Avatar
Upgraded Water Pump Kit.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 10-30-2010, 03:12 PM
