rmcdonnell's Avatar
Finding the ABS controller and connectors.
My ABS fault went away, and like these intermittent problems often do, has returned.
Can somewhere tell where I find the ABS controller brains, and an 8 pin connector that connects all the wheel sensors?
I've looked under the dash but I'm not sure what I'm looking at or for.
Cheers
Rissole
944 Alpine White '89 2.7L
Old 10-31-2010, 10:16 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
You have to remove the passengers side inner fender cover as the controller is located in back of the inner fender - have pfun...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-31-2010, 11:57 AM
rmcdonnell's Avatar
I've had the inner wheel arch cover off in the past and know that's where the pump is. From memory I think there are two relays on some sort of bracket behind the pump, and maybe a ground strap.
I don't remember seeing the 8 way connector and controller, but you think these parts are under the wheel arch cover too.? (I assumed they were somewhere on the inside). Are they part of the gubbins behind the ABS pump, with the relays?
Old 10-31-2010, 04:36 PM
In the Fires of Hell.....
kdjones2000's Avatar
The computer is inside of the car, and should be on the passenger side, behind the kick panel.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-31-2010, 04:39 PM
The ABS computer is inside the car, passenger footwell. Remove the side carpet panel and you'll see it.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-31-2010, 06:19 PM
rmcdonnell's Avatar
Thanks Bazar01,
I just whizzed outside to take a look: and you're on the money. Mine is RHD , and so is under the vertical RH carpet in the drivers foot well, but there it was. A damn site more accessible than I expected too. I shall have a poke about when I can, I will make some breakout leads to figure out what's happening, and if the wheel sensors are OK.
cheers
Rissole
Old 11-01-2010, 06:34 AM
